Auto lights - 2013 1.2TSI BlueMotion Comfortline
- sparrow77
- Drives: 2013 1.2TSI BlueMotion 5spd
Hello,
Having ordered and used a cheap knockoff auto light switch for about a week, I've realised it makes a lot of compromises in functionality and comfort to do just the one thing - switch headlights on in the dark. If you're interested, here's my take on (this particular) knockoff auto light switches:
- Build quality is poor (although you won't be using it much due to the auto function)
- Uses parking lights as daytime lights instead of the car's built-in daytime lights
- Module is not straight in the dash, e.g. "Auto" text is crooked and "0" is off-centre (6C switch is a slightly different design to 6R - thanks to iichel for the info)
- Interior dimming has no effect on module LEDs, always at full brightness
- Start-stop-function causes headlights to briefly turn off when car starts up, leading other drivers to think you are flashing your headlights at them
- Because the car isn't coded for auto lights, delayed light turn off (and coming home/leaving home lights) cause the door chime to ring
All fairly niggly and annoying faults just to get your headlights on automatically.
This is what I bought: https://www.aliexpress.com/item/33048291793.html
So I wonder - what is the most cost-effective way of getting more or less OEM functionality and features without all the drawbacks of the knockoff switches? (Paging iichel/Ciclo? )
Re: Auto lights - Cheap switch vs. entire OEM system
I guess it depends on whether your car has a suitable BCM (start/stop or bi-xenon from factory). Otherwise you're looking at a bcm replacement/upgrade and that's where cost effective ends..
- sparrow77
I have start-stop, yeah, but haven't had a chance to run a VCDS scan yet. Would be nice to have rain sensors and other features, but it looks like a lot of electrical work. Thankfully you and others have posted great how-to's with lots of photos.
Looks like you bought a polo 6c light switch though. Anyway, if you have start stop, a rain and light sensor and vcds, your can install a wiring loom and a lightswitch from a golf 6. That way your installation is fully OEM with proper functioning.
- sparrow77
With AliExpress, you never know what you get... It has the correct 14-pin connector for my car, but yes the switch is chrome instead of satin.
I don't have a rain sensor, but I would like to install one in the future. I can consider that later, though.
If I just want auto lights and CH/LH, I guess my BCM is compatible so I would only need:
- A (modified?) wiring harness from the LCM to the BCM, with two new pins going to the BCM
- A new, OEM (not a copy) auto switch
- VCDS to code the functions
Is this correct? This is based on Ciclo's guide: https://docs.google.com/file/d/0B2nv91Y ... E1bk0/edit
Yes but you must have the rain and light sensor for the auto lights to work. Without it, the installation will not work.
- sparrow77
Ah of course, the cheap Chinese ones have the built-in sensor. Okay, so I guess that's also not a big deal - there is also a guide to install the rain sensor on the window. Thanks a lot for the help!
You're welcome. There are two kinds of rain sensor. The 1k0 and the 5k7. First one is square, the second is round. They have mount glued to the glass and hold the auto dimming mirror.
- sparrow77
Yeah looks like there are two versions. I found a spare parts/crashed car with a sensor and mirror locally near me. Hopefully everything works and comes off in one piece...
Perhaps it's also possible to take the mirror mount but they are not expensive to replace.
- sparrow77
I managed to get an autoscan of my car through a coworker. I was wondering if you could confirm for me that my BCM is modifiable for factory autolights and xenons, and that I won't need to buy another one? It seems to be an edge case as its an 088 F. Thanks!
Would 6C factory LED headlights also be compatible with the BCM, if I happened across a set cheap enough?
Are there really any retrofit limitations this BCM might have? Sorry, very broad question.
Don't worry about the fault codes.
Thursday,16,January,2020,17:00:51:56149
VCDS Version: 19.6.2.0 (x64)
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: WVWZZZ6RZDY090318 License Plate: LRR-510
Mileage: 90430km-56190mi Repair Order:
Chassis Type: 6R-VW25 (6R0)
Scan: 01 03 08 09 10 15 17 19 25 44 56 61
VIN: WVWZZZ6RZDY090318 Mileage: 90430km-56190miles
56-Radio -- Status: Malfunction 1010
Address 01: Engine (J623-CBZC) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 FJ HW: 03F 907 309 K
Component: SIMOS10.23AH10 4038
Revision: --H10--- Serial number:
Coding: 001100B6202401080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070FJ 004007
VCID: 6FEDA0EAB64659374E-803A
1 Fault Found:
10478 - Charge Pressure Control Actuator
P334A 00 [032] - Electrical Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 90023 km
Date: 2020.01.02
Time: 16:23:14
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 63 °C
Intake air temperature: 45 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 12.187 V
Unlearning counter according OBD: 15
Charge pressure actuator: specified value-PWM_BPA[0]: 0.000 %
POSN_DIF_BPA[0]: -0.00 %
Charge pressure actuator: adaptation for upper stop-VP_BPA_AD_TOL[0]: 0.8000 V
TQI_TCHA_PROT: 1023.96875 Nm
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3217600B2842814E384D900501300
VCID: 020BF95E99D4445FB1-8056
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AB.clb
Part No SW: 6R0 820 045 N HW: 6R0 820 045 N
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 39795EB2B082C787A0-806C
Part No SW: 6R0 937 088 F HW: 6R0 937 088
Component: BCM PQ25 Re4 H50 0353
Revision: BU050001 Serial number: 0456 251120043
Coding: 24B02BBF08A10000003009B02E2B0DD05FC0612F7E060041A00000000000
Shop #: WSC 124697 483 00190
VCID: 41893652D8529F47E8-8014
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU011091200011248
Coding: 58BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU010091200015821
Coding: 58BC30
Subsystem 3 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU004091200010377
Coding: 58BC32
Subsystem 4 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU004091200015471
Coding: 58BC32
4 Faults Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Fault Status: 00100010
Fault Priority: 6
Fault Frequency: 1
Reset counter: 6
Mileage: 90287 km
Time Indication: 0
Date: 2014.06.03
Time: 00:00:09
00447 - Function Limitation due to Over-Voltage
001 - Upper Limit Exceeded - Intermittent
Fault Status: 00100001
Fault Priority: 6
Fault Frequency: 5
Reset counter: 0
Mileage: 87321 km
Time Indication: 0
Date: 2014.03.25
Time: 14:44:07
00901 - Back-Up Lamps
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 5
Reset counter: 228
Mileage: 90207 km
Time Indication: 0
Date: 2014.06.01
Time: 20:56:56
00968 - Right Turn Signals
010 - Open or Short to Plus - Intermittent
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 2
Mileage: 90207 km
Time Indication: 0
Date: 2014.06.01
Time: 21:13:47
Address 10: Park/Steer Assist (J446) Labels:| 6R0-919-475.clb
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47361225100949
Coding: 108001
ROD: EV_VW250ParkiAssis2.rod
VCID: 3E734DAEA1ACE0BF95-806A
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX01D2R6F
Coding: 00314D
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9B117EED645C1F39-801E
Serial number: 3575HRB405D1IMPM4GE4
Serial number: 3585HRB405F1IMPMB8OG
Serial number: 3515RRB406919PPQCHLJ
Serial number: 3525RRB405B1AP60BOUZ
Part No SW: 6R0 920 860 K HW: 6R0 920 860 K
Component: KOMBI H05 0605
Coding: 140E01
VCID: 3C7747A6B7B0F2AFBB-8068
Address 19: CAN Gateway (J533) Labels:. 6R0-907-530-V2.clb
Part No SW: 6R0 907 530 E HW: 1K0 907 951
Component: J533 Gateway H38 0041
Revision: H38 Serial number: 130912F2000379
Coding: 2500C2
VCID: 356152829C9A23E744-8060
1 Fault Found:
01304 - Radio
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 5
Mileage: 90207 km
Time Indication: 0
Date: 2014.06.01
Time: 21:56:56
Component: IMMO H05 0605
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADBB1FE8DA4BC1F19-803E
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11250
Shop #: WSC 00788
VCID: 306F6396F7F806CF17-8064
Part No SW: 5M0 035 186 J HW: 5M0 035 186 J
Component: Radio RCD310 042 0082
Revision: 01000001 Serial number: VWZ1Z2M4606877
Coding: 05000400020001
VCID: 33656C9A92EE3DD76A-8066
2 Faults Found:
00856 - Radio Antenna
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 6
Mileage: 90256 km
Time Indication: 0
Date: 2014.06.03
Time: 18:23:14
00821 - Antenna 2 for Radio (R93)
Fault Priority: 5
Fault Frequency: 1
Reset counter: 6
Mileage: 90256 km
Time Indication: 0
Date: 2014.06.03
Time: 18:23:14
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 6R0 907 534 HW: 1K0 907 951
Component: Batt.regelung H38 0041
Coding: 032B7A64
VCID: 74E7AF86D7607AEFB3-8020
Subsystem 1 - Part No SW: 6R0 915 181 E HW: 6R0 915 181 E
Component: J367-BDM H08 0181
Serial number: 00000000004970099393
End-------------------------(Elapsed Time: 02:25)--------------------------
Re: Auto lights - 2013 1.2TSI BlueMotion Comfortline
This BCM has a lot of options. You can do OEM auto lights, but you need the rain and light sensor.
It cannot do 6C LED, you need a 7E0 BCM Max for this. It can however do OEM bi-xenon.
