Usb issues after full nav media upgrade
Posted: Wed Mar 18, 2020 7:43 pm
by Robbo770
Hi folks, my polo is first of the 6c’s being a SEL had mib2 installed with Bluetooth and was able to have mirror play.
I replace the display to full nav unit and 874b media unit, now have working Bluetooth, WLAN, phone, voice and Nav just waiting on new map sd card.
The Apple CarPlay is ready to use but it’s not seeing a phone plugged in at the USB socket, think I need to upgrade the socket, maybe the wiring too?
Anyone any advise and part numbers or even if you have the required parts would be great.
Cheers Rob
Re: Usb issues after full nav media upgrade
Posted: Sat Mar 21, 2020 4:22 am
by Robbo770
So after much trawling I found this great post on another site covering exactly what I need to find out.
If you have a basic 510 stereo system you will need to get the usb cable and new socket for android / CarPlay / mirrorlink when updating the media unit in the glove box
https://www.drive2.com/l/533524549434606087/
Also found this very nice pic for putting usb in the rear
https://images.app.goo.gl/QnVmoLLe8oA49wJa6
Posted: Sun Mar 22, 2020 12:42 pm
by Robbo770
So I received a new green socket new 2017 version 5Q0035726E in the post yesterday, not facial fitting to try and get my Apple CarPlay working.
Now my car has mib2 but being 2014 only a red socket fitted when new, not compatible with CarPlay.
So the cable connection is polarised for a red socket by
1 edge preventing fitting to the green socket, bar that identical in wire orientation.
So I trimmed this off to allow trail of the system.....
- Red con 1
- Red con 2
- Red con 3
- Red con 4
- Red con 5
- Completed connection
I fired up the car and success! Apple CarPlay fully operational
- Car play
I am awaiting a USB hub to try and expand the usb connections in the car with voltage converter for 3 of them.....
- Usb hub
Don’t know if this will work, but as the interior is current apart fitting this in the rear for power only for the back seats
- Rear usb hubs
Hoping heated seat kit arrives Monday so I can fit everything all at once
Posted: Mon Mar 23, 2020 1:14 pm
by Robbo770
So the other usb socket arrived today which has the surface mount format.
Decided to compare the 2 units and ends up they have identical inner boards so here is the info in the pics folks for info.
Posted: Mon Mar 23, 2020 4:26 pm
by Robbo770
Anyone got a 2017 wiring guidance for the usb hub power 4 pin connector?
- 17 3 port hub usb
Posted: Tue Mar 24, 2020 1:11 pm
by Robbo770
So the hub arrived and this is what it looks like close up
Just need to see if anyone can help work out the 4 pin connections
As this is the only info I have found.....
Posted: Tue Mar 24, 2020 8:48 pm
by Robbo770
So after several hours of travelling the internet I found this which makes more sense,
Pin 1 - 12 volts
Pin 2 - earth ( taken from usb earth feed)
Pin 3 - n/a
Pin 4 - media unit =5 volt ( taken from original usb power feed)
The unit connections of the actual Fakra ones are
I need to get my hands on 3 A type Fakra 4 pin cables to allow me to plug the 3 socket in.
Posted: Tue Mar 24, 2020 9:01 pm
by Robbo770
Reason we have to change the usb sockets also now identified, however if a cable mod is done the same sockets also will work
Cable mod is to rotate 180 deg and make it refit the plug
Posted: Thu Mar 26, 2020 10:56 pm
by andy_256
Hi Robbo770
Great post....My son bought his first car recently, a 3 door Polo, and I've treated him to an upgrade of the media unit through Vagtech as he wanted DAB, NAV and Car Play. Had it fitted locally to me with new aerial and leads and all works fine except for Car Play.
Now i've worked out, and you have confirmed that the USB is not active so only charges the phone. I've purchased the correct one, green end, and will be fitting this weekend - that can be my daily exercise. The lead for the socket is purple like yours, are you suggesting that if I adapt it like yours it will work for Car Play, so i don't need to change the lead?
Thanks in advance
Posted: Fri Mar 27, 2020 12:52 pm
by Robbo770
Hi, correct, trim the tab stopping it fitting the green new usb socket and bingo all will work
Posted: Sat Mar 28, 2020 1:07 pm
by JaegerStriker
Robbo770 wrote: ↑Wed Mar 18, 2020 7:43 pm
Cheers Rob
where did you get the replacement from, was it full package ie screen and glovebox unit?
was it all CP unlocked?
Posted: Mon Mar 30, 2020 1:05 am
by Robbo770
I just bought a full nav / voice/ dab/ Bluetooth/ appleplay / mirror play unit from
vagnavinfo@gmail.com which with a nav display unit will immediately work with no issues regarding CP.
You might need the vdcs system to be updated for model and rear camera just once all plugged in, start up screen.
Give them an email tell them Rob in aberdeen put you on to them the unit comes with a new GPS aerial that you fit when doing the swap.
