Instrument panel swap
- Drives: polo 6r 1.2tsi DSG
Good day,
I accidentally came across a topic for changing the instrument panel.
now that seems cool to me.
However, I have a few questions about this.
If I take the GTI cluster.
then I have to update it so that it contains my current polo information (mileage, immobilizer, etc).
And then it has to be coded to the polo.
now my question is.
Is this further Plug and play?
Are the GTI cluster MFD or MFD +?
will the analog coolant temperature gauge and fuel gauge also work, or should wires be laid for this?
If the gti cluster is MFD +, will options like Oil temperature work?
And can it cause problems that the gti cluster goes up to 280km / h instead of 240km / h?
now my question is.
Re: Instrument panel swap
A GTI MFD + instrument panel must be adapted to your car using special tools.
My recommendation due to proximity:
Contact madwarlock (Slavik), he is a user of this forum, he can do it for a reasonable price, and the process is totally safe.
- Everything will work as it should. (oil temperature included)
- You don't need additional wires.
- No problem due to the Max speed ... in fact, the ICs with 280 Km/h are more accurate.
Awesome Thank you for your reply.ciclo wrote: ↑Tue May 26, 2020 1:08 pm A GTI MFD + instrument panel must be adapted to your car using special tools.
I just needed to make sure everything works.
The guy who sell the panel claims he is able the tranfer the data.
So i first going for this guy first. if is isnt albe to manage it. i will contact madwarlork.
thanks again!
Edit:
now I am curious. Can I switch on needle sweep with the GTI instrument panel?
cypress wrote: ↑Tue May 26, 2020 2:21 pmAwesome Thank you for your reply.ciclo wrote: ↑Tue May 26, 2020 1:08 pm A GTI MFD + instrument panel must be adapted to your car using special tools.
thanks again!
Edit:
Yes.
I recently responded to an insturment panel, which was a 2 hour drive.
In itself no problem, but it is annoying that you get a message after more than 1 hour driving that the insturment panel is no longer available ...
So that was annoying ...
Now I have responded another.
Only that is a Type C instead of D, is there a lot of difference between the 2?
- Drives: POLO 6R DSG 2013
Hello guys,
I want to replace my IC 6R0920860J with 6R0920870.
My POlO is 1.4 MPI.
So 6R0920870 can work in my CAR?
It is MFD or MFD +?
Thank you,
My POlO is 1.4 MPI.
It is MFD or MFD +?
Thank you,
Difficult to say, google doesn't really have the answer click
It looks like it's the 6R GTI cluster (revs to 8000, speed to 280 km/h) and that should work in your 1.4 MPI engine (CGGB)
Do you have a picture of the instrument cluster you want to place?
Does it matter that the cluster does not go up to 280 km / h?
The cluster I have goes up to 240.
But the revs go up to 8000.
6R0920870C is the number: P
No it should not matter
Just checking,
It is then transfer the data from the cluster and then encode it to the polo?
do things need to be changed?
Or is that it?
Or is that it?
Just transfer immo data if you have a petrol car.
This is the cluster
https://archiwum.allegro.pl/oferta/6r09 ... 89377.html
How can i find if display oil temperature?
Hello again guys,
Does anyone know what parts code I would need to have TPMS directly on My Polo?
Custer, BCM, etc.
Thank you in advance.
Here is my scan
Saturday,20,June,2020,10:27:55:59248
VCDS Version: 19.6.2.0
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: WVWZZZ6RZDY197086 License Plate:
Mileage: 179170km-111331mi Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 37 44 55 56
VIN: WVWZZZ6RZDY197086 Mileage: 179170km-111331miles
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 BJ HW: 03C 906 024 BH
Component: CGGB MM4HV G 8997
Revision: --H09--- Serial number:
Coding: 0000077
Shop #: WSC 00788 648 00255
VCID: 67DD64D8558AA47706-5124
Readiness: 0000 0000
Part No SW: 0AM 300 060 HW: 0AM 927 769 D
Component: GSG DSG AG7 431 4560
Revision: 00043014 Serial number: CU501301245051
Coding: 0000020
Shop #: WSC 35070 001 1048576
VCID: 67DD64D8558AA47706-5106
Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Component: ESP9.0i front H02 0002
Serial number: --------------
Coding: 21DD2885412C00C784141471825700400905
Shop #: WSC 01383 785 00200
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
VCID: 0F2D6C78D6BA1C372E-805A
Component: LENKW.SENSOR H06 0070
Serial number: 26011304650453
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF321BCE11005BFD5-802A
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AB.clb
Part No SW: 6R0 820 045 M HW: 6R0 820 045 M
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 387FF7A48BB4FB8F5F-806C
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 089 F HW: 7H0 937 089
Component: BCM T5GP Li4 H50 0251
Revision: BS050001 Serial number: 0465 300111639
Coding: 64B029B808A1000001280EC168AB8FD0F0C867FF60AF30C1200000000000
Shop #: WSC 64564 324 38760
VCID: 3979F2A0B0BEE287A0-806C
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 110113 05 54 0403
Coding: 06302D
Subsystem 2 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1621
Serial number: KU0KU019111200016909
Coding: 18BC30
Subsystem 3 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1621
Serial number: KU0KU028111200012325
Coding: 18BC30
Subsystem 4 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-MD9 H04 0103
Serial number: 29190001675950069296
Coding: A50000
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 7N0 919 475
Component: PARKHILFE 8K H06 0106
Revision: -------- Serial number: 28261420900569
Coding: 308104
Shop #: WSC 02739 790 50316
VCID: 3B75E8A8B282D097B2-806E
Component: VW10Airbag01K H10 0020
Revision: -------- Serial number: 003GX01K0BUS
Coding: 00314B
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9BBD6CED58791F39-801E
Serial number: 3575HRB405H1S6UQ59C3
Serial number: 3585HRB405H1S6UQCPS0
Serial number: 3515RRB400O50D62K27X
Serial number: 3525RRB400O50D62DIA3
Part No SW: 6R0 920 860 J HW: 6R0 920 860 J
Component: KOMBI H03 0306
Serial number: 00000014597526
Coding: 140E01
ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01720
ROD: EV_DashBoardUDSJCIPQ25_A01.rod
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 089
Component: GW-K-CAN TP20 H50 0251
Revision: BS050001
Coding: 002000
VCID: 70EF0F84A34463CF57-8024
Address 25: Immobilizer (J285) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H03 0015
Serial number:
ASAM Dataset: EV_ImmobUDSJCIPQ25 A01003
ROD: EV_ImmobUDSJCIPQ25.rod
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 3C8 035 279 A HW: 3C8 035 279 A
Component: RNS315-EU H62 0319
Serial number: VWZAZ2N0156574
Coding: 000002510200000000030002
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 295922E0481E5207D0-807C
Data medium:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_V4 0050
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11250
Shop #: WSC 00788
VCID: 306FCF84F7C423CF17-8064
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
VCID: 77FD3498CE2A34F796-8022
End-------------------------(Elapsed Time: 03:09)--------------------------
Custer, BCM, etc.
Here is my scan
www.Ross-Tech.com
Coding: 0000077
Coding: 0000020
Coding: 01
Revision: 0003SH02
Coding: 06302D
Coding: 18BC30
Coding: 18BC30
Coding: A50000
Coding: 308104
Coding: 00314B
Coding: 140E01
Revision: BS050001
Coding: 002000
Serial number:
Data medium:
Coding: 11250
Shop #: WSC 00788
