RCD 200 Stock Radio
liamchaps
RCD 200 Stock Radio
Post by liamchaps »
I'm trying to install an Edge 12" Sub on the stock radio
I can either use High-level input or get a low-level adaptor but not sure which to go with
And how would I go about getting a remote turn on, could I use the cigarette lighter as that is controlled with the ignition
Dink
Drives: 2015 GTI
Re: RCD 200 Stock Radio
Post by Dink »
If it's got a high level input then use that (basically has the hi-lo converter built in). You could just run an extra set of wires from the rear speakers.
As for remote turn on you could just use an add a fuse adaptor in the fuse box off an ignition switched supply and stick the lowest rated fuse you can find in it.
liamchaps
Post by liamchaps »
So since I don't have rear speakers I have four spare connections in the wiring harness should I use them or just splice the front speaker wires in the harness or does it not really matter?
Dink
Drives: 2015 GTI
Post by Dink »
If there's an output on the channels of the headunit use them. Probably be the easiest option.
