1.4 tdi polo air filter replace
Does anyone know to change the air filter on a 1.4 tdi polo. The screws are on the underside and are impossible to get to unless I remove the filter box.
- Platinum Member
Re: 1.4 tdi polo air filter replace
Are you sure, you should unscrew couple of torx t20 screws
- Drives: Polo Blue GT
It is not difficult but as you are clearly concerned look on YouTube, there are a number of videos that will talk you through it.
I got it. I had to take the airbox out and take out 11 20tx screws
That’s great, it feels good when you solve a problem that had been bugging you. The Polo will be pleased too!
