Aditya's Polo 6R GT TSI 1.2
- Drives: Polo GT 1.2 TSI
Re: Polo 6R GT TSI 1.2 BCM Max + Auto Headlight + HBA
hey ciclo,
so after searching for hours found this seller on aliexpress who is ready to ship direct tpms instead of aliexpress being banned in India.
https://aliexpress.ru/i/4000273199694.html
this is the product which he has and is ready to ship, its costing me around 25000INR
Will this product work with my car?
Can you help me with any other leads regarding this?
Have left a message for patil, he is gonna contact me soon i guess busy with some work
Regards
Regards
Hi Aditya,
I have sent you the link of the person to contact regarding direct tpms kit. I personally know the seller and he sells genuine new products, bit on expensive side but ensures you peace of mind. Talk to seller about your requirements and he should help you. Even he can parametrise the module.
In any case if you end up needing parametrisation, contact anyone locally having Odis or VCP.
If you don't find anyone, as a last option, I can do it for you if you send me the tpms module, only in my free time.
Good luck
Good luck
I tell you a secret that you should not tell anyone:
The 3AA907275B sensors are also supported by the 3AA907273F unit.
https://aliexpress.ru/item/100500201050 ... 8400768748
https://aliexpress.ru/item/400029098173 ... 1208595472
Hey Patil, I am somewhat concerned about the covid in India, I send you a warm hug with the hope that soon the current situation will begin to improve ...
A big hug my dear Doctor.
Thank you for the hug dear master, it helps.
The situation in my country is precarious, the burden on the health sector is overwhelming. The society as a whole has failed miserably, the irresponsible behaviour of citizens and authorities led to utter chaos beyond comprehension.
Humanity is the biggest threat to humanity.
The statistical data of covid cases and deaths that is flowing in from hospitals across the country is very disturbing, and worst is yet to come.
The situation will improve eventually, but after paying a hefty price.
"Safety regulations are written in blood."
Namaste
It is a great challenge that we ALL must overcome, especially in our individual behavior.
Namaste Patil, all my respects.
Hello everyone
Hi ciclo, hope you are doing fine
Btw used your guide and installed tpms and heated ovrms. Now my car is 2 years old and 32000kms. Recently had to change the steering rack and water pump (manufacturing defects) thankfully it was covered under warranty. Donβt get why such inferior quality parts in India.
Anyways here are the pics of the tpms and I know still have to parameterize the unit. Must say DIY are fun to do
Hi adityagttsi. Looks great! Enjoy it!
I could no longer live without the TPMS, the tire pressure is the first thing I check in the MFD after traveling about 100 meters, it gives me peace of mind to face any trip without worries.
Once the tires have warmed up, I again observe the increase of pressures. It's great to have this data!
- For me it would be great if the tire temperature was also displayed, since it is also monitored.
Heated outside mirrors are very useful.
I don't have it in automatic mode because I like to observe condensation phenomena, it also alerts me about the changes in temperature outside.
I would have it in Automatic mode if I lived in more humid or colder climates.
A hug.
A hug.
Hi Ciclo, hope you are doing great.ciclo wrote: βTue Feb 28, 2023 11:35 am Hi adityagttsi. Looks great! Enjoy it!
A hug.
Thanks for the automatic function for heated mirrors. After trying it I have disabled it as its not useful for climate conditions in India as I use the heated mirrors in rains only.
Latest Update.
I was hell bent on getting the auto folding mirror function on my POLO. But then there were only two options, the first one being the Oem option (Replacing the wrms which are very expensive) and the other option was to get an aftermarket kit which I wasn't keen on doing it.
Luckily I found that T6 which have BCM - 090D get auto folding mirror functions. The way it works is that mirrors fold on long press of lock button and unfold on ignition. And this function is supported by Channel 84 in Central Electronics. Also the channel is available on 089D BCM only.
And to my surprise it did work on my car. Mirrors fold on long press of Lock Button on keyfob. (This has a success rate of 100 Percent). Mirrors also unfold on ignition (But then this doesn't seem to work always, as in sometimes it will and sometimes it wont)
Can the experts of this forum help me with unfolding function, do i need to adjust some code or adaptations.
Thanks.
Re: Aditya's Polo 6R GT TSI 1.2
Hi Aditya, how do you do?
I am regularly normal, I am not in my best moments.
Draw your own conclusions.
- Channel comparison between BCM MAX models C, D and E from channel 75. (84,85)
My 6R currently has the E.
My folding mirrors worked with all of them the same way you describe, 100% folded and unfolded. I did not change the values of the BCM adaptation channels for the folding mirrors. https://www.youtube.com/watch?v=AryMyadL8bg
With the information you provide it seems that the way of making folding mirrors work has changed. I'll do some testing with channels 84, 85 as soon as possible, although I don't expect any different results on my folding mirrors.
On the other hand, there is the coding of the WRMs, but it is a mystery if the following coding table is applicable to all the WRMs models that exist (HW/SW) from 2010 to 2019 in the PQ25 family.
... as you can see in the table, Byte3 Bit0 and Bit1 are dedicated to the mirror folding function... maybe it is necessary to also activate Bit5 for PQ25.
As you already know, once the coding is done, it is necessary to reconfigure the window comfort function again so that the changes in the WRMs coding take effect.
Please keep us informed of your tests. Thank you.
I tested channel 84 on my BCM 'E' from 0 to 1, it has effects on the folding mirrors function, but in my case (with WRMs with SW for folding mirrors) the mirrors do not unfold when turning the ignition switch.
I recode the channel from 1 to 0 and the folding mirrors work fine again, both remote fold and auto unfold when I turn the ignition switch. 100%.
I also tried channel 85, it has no effect on folding mirrors.
So i today did the installation of 6C GTI Lights, along with T10 to T14 harness. Connected the necessary wires to BCM.
Tried to do the coding, but there is a problem the Parking Lights are working in the DRL(When headlight switch is off)
Second problem proper parking lights are not working when you turn the headlights on or when you keep the headlight switch in parking light position
Here is the auto scan, if you guys could help me that would be great.
Thanks in advance
Monday,06,November,2023,18:42:08:16365
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.3.0.0 HEX-V2 CB: 0.4631.4
Data version: 20230228 DS346.1
www.Ross-Tech.com
VIN: MEXJ19604LT057986 License Plate: 8002ERROR
Mileage: 52960km-32907mi Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 56 65
VIN: MEXJ19604LT057986 Mileage: 52960km-32907miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number: CVN: 9408DB59
Coding: 00250056232400080000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
VCID: 6D87C9A91D1200B2D45-8038
VINID: 755A1A04918011C9001472481803BBEAEB
Readiness: 0110 0100
Part No SW: 0AM 300 043 C HW: 0AM 927 769 F
Component: GSG DQ200G2_PQ 050 2601
Revision: 00005008 Serial number: CU501906266575
Coding: 0000020
Shop #: WSC 01357 011 00200
VCID: 2B0307B1EF06CE828A1-807E
Part No SW: 6R0 907 379 CB HW: 6R0 907 379 AS
Serial number: --------------
Coding: 62DD2463422803C7461D24714257C0800908
VCID: 0059801D3A80FDDA0F3-8054
Serial number: 07071913470686
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5FEE540748B2A7DF-802A
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 41DF4519718A34D240D-8014
Part No SW: 7E0 937 090 D HW: 7E0 937 090 D
Component: BCM PQ25 Max4 H82 0762
Revision: B9082001 Serial number: 8601 320180219
Coding: 3AB82BFF48B30400013806107CEF9ED006C0670F608D31D1220000030000
Shop #: WSC 18376 273 19267
VCID: 2C0104ADE608C9BA83B-8078
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 180619 05 50 0106
Coding: 066800
Subsystem 2 - Part No SW: 6R0 959 802 EF HW: 6R0 959 802 EF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 023 2551
Serial number: 13202848190716085938
Coding: 350000
Subsystem 3 - Part No SW: 6R0 959 801 ED HW: 6R0 959 801 ED Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 023 2551
Serial number: 13102849190711213513
Coding: 040000
Subsystem 4 - Part No SW: 31G 959 442 HW: 31G 959 442
Serial number: 0401812433500024CX3J
Coding: 250000
Subsystem 5 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
Component: J388__TSG_HL 022 1552
Serial number: 13102728190711175909
Subsystem 6 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
Component: J389__TSG_HR 022 1552
Serial number: 13102729190711052611
1 Fault Found:
01504 - Bulb for License-Plate Light (X)
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 21
Mileage: 52961 km
Time Indication: 0
Date: 2023.11.06
Time: 18:34:25
Address 10: Park/Steer Assist (J446) Labels:| 6R0-919-475.clb
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47301131801342
Coding: 108002
Shop #: WSC 00793 648 00255
ROD: EV_VW250ParkiAssis2.rod
VCID: 3E253EE500F44B2A3DF-806A
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 Q HW: 6C0 959 655 Q
Component: Airbag VW12 001 0503
Revision: -------- Serial number: 003FZAAYABLK Dataset Number: V03935303ZE 0001
Coding: 880000000000000054000000008000000065
Shop #: WSC 01383 785 00200
ASAM Dataset: EV_AirbaVW12TS6VW25X 001001
ROD: EV_AirbaVW12TS6VW25X_VW25.rod
VCID: 41DF4519710A34D240D-8014
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H05 0805
Coding: 140800
VCID: 47CB5B015F2E0AE28E9-8012
Part No SW: 7E0 909 901 HW: 7E0 937 090 D
Component: GW-K-CAN TP20 H82 0762
Revision: B9082001
Coding: 002300
VCID: 6889B8BD3270259AA73-803C
Component: IMMO H05 0805
VCID: 6A8DC2B52CFC178AB17-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Dataset Number: V03935277QZ 0001
Coding: 0001000000000000
Shop #: WSC 12345 123 12345
ROD: EV_SteerAssisNSK_014_VW12.rod
Part No SW: 6RF 035 187 C HW: 6RF 035 187 C
Component: Radio 557 5532
Revision: -------- Serial number: VWZ7Z2T8105070
Coding: 1E000440000005
VCID: 49CF5D3949BAFC9298D-801C
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H06 0011
Serial number: 30000000451195
ROD: EV_RDKBERU30_005.rod
VCID: 372B2BC12FCE7A62FE9-8062
End----------(Elapsed Time: 01:19, VBatt start/end: 12.2V/12.3V)-----------
Thanks in advance
www.Ross-Tech.com
Coding: 0000020
Coding: 01
Revision: V0000000
Coding: 066800
Coding: 350000
Coding: 040000
Coding: 250000
1 Fault Found:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 21
Mileage: 52961 km
Time Indication: 0
Date: 2023.11.06
Time: 18:34:25
Coding: 108002
Coding: 140800
Revision: B9082001
Coding: 002300
Three scenarios best way i could explain it
Headlights switch 0 position and DRL are on
Headlight switch parking lights position
Headlights on(Auto and manual) and parking lights are off
- IMG_0550.jpeg (2.85 MiB) Viewed 1394 times
- IMG_0551.jpeg (1.8 MiB) Viewed 1394 times
- IMG_0553.jpeg (3.25 MiB) Viewed 1394 times
As soon as possible I'll take a look at it, between today and tomorrow.
Good night, have sweet dreams!
Thank you ciclo. Means a lot.
From what i could read on this forum about led headlights. I have come to know this that you need BCM 8IT for Led headlights or you need to parameterize it.
If you donβt then the Parking Lights wont work with Headlights and Parking Lights.
Also if my BCM does not support LED Lights then can i parameterize using ODIS?
First I checked your new BCM coding comparing it to 6R IND with LED headlights from the factory.
I have modified some Bytes...
Please try this new BCM coding and report the results. Thanks!
3AB82BFF48B30400013806307CEF9ED002C0604F60CD39F1230000030020
Faults may arise, but we need to know this. Don't worry if this happens, they will be corrected.
From what you say about the current operation of your new '6C/6R' LED headlights, it is highly likely that you need to parameterize your BCM (PWM value for position/parking/side lights), which can be parameterized with VCP and ODIS.
It is explained in the firegrafik thread on Drive2.ru https://www.drive2.ru/l/489696641561919499/ PWM Value with POS/TFL lights and activited Pos-lights...new value = 28
