Blue GT 1.4tsi 150ps flat spot
edward918
Drives: 6C BlueGT
Post by edward918 »
2nd gear, floor it: Boost, slight flat spot between 4k - 5k rpm then back on boost again. Anyone else been having the same issue? Is it anything a remap can't fix or shall I leave it?
edward918
Drives: 6C BlueGT
Re: Blue GT 1.4tsi 150ps flat spot
Post by edward918 »
The issue is still apparent, here's a video of it: https://youtu.be/HLHWiZ_tLFY
Doesn't happen in any other gear apart from 2nd for some reason...
edward918
Drives: 6C BlueGT
Post by edward918 »
Okay, turns out the possible cause is because of the Turbo Wastegate Actuator not having enough grease around it, causing it to stick momentarily. The solution is to either get a garage to remove and regrease the part or to have a completely new part installed. :mrgreen: I'll carry on driving with the issue as it only happens occasionally. Will have to fork out for a new part if and when the problem gets worse.
albob
Drives: BlueGT
Post by albob »
Glad you got it sorted (and useful to know the solution..)
