Good day, I have a vw polo with the ABS module need to be coded. I’d replace the whole security system on it because the engine control was bad. The vin # WVWZZZ6RZDU14187 and the new vin# WVWZZZ6RZDU035129
Thanks in advance
How to code vw polo abs
- Drives: Polo SEL 1.4 tdi 2014
Re: How to code vw polo abs
The abs unit I believe is a write once only unit, you I think have to buy a new blank one and programme for your car, you need the original unit coding, and mods done so it could be code written specifically for you, only user I know who could help is the guru, ciclo
