Re: VCDS advice
Posted: Sun Oct 11, 2020 3:13 pm
Saturday,10,October,2020,14:39:20:00009
VCDS Version: 19.6.2.0
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: WVWZZZ6R######### License Plate:
Mileage: ######km-#####mi Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 09 15 17 19 25 44 56
VIN: WVWZZZ6R######### Mileage: ######km-#####miles
44-Steering Assist -- Status: Sporadic communication error 1000
Address 01: Engine (CGP) Labels: 03E-906-033-AZQ.lbl
Part No SW: 03E 906 023 AL HW: 03E 906 023 L
Component: SIMOS91 1.2l 4V 4523
Revision: --H04--- Serial number:
Coding: 0000031
Shop #: WSC 00000 000 163936
VCID: 69D908A34379EB0710-515A
Readiness: N/A
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 R HW: 6R0 907 379 R
Component: ESP8.2i front H04 0002
Revision: --------
Coding: 230224E3217200B6C42E24E484D600801100
Shop #: WSC 02069 000 00000
VCID: 4D91DC3310D117271C-8018
Part No SW: 6R0 937 087 D HW: 6R0 937 087 D
Component: BCM PQ25 H+4 H46 0207
Revision: BF046001 Serial number: 0147 032102084
Coding: 64B029BF08A10048002000003D2B0C900040410F60060000200000000000
Shop #: WSC 31414 790 31414
VCID: 3E738BFFA977BCBF95-806A
Subsystem 1 - Part No SW: 6R0 959 802 H HW: 6R0 959 802 H Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 005 0811
Serial number: KU0-KU005.11.0911203
Coding: 08BC30
Subsystem 2 - Part No SW: 6R0 959 801 K HW: 6R0 959 801 K Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 005 0811
Serial number: KU0-KU005.11.0912490
Coding: 08BC30
8 Faults Found:
00910 - Indicator Lamp for Emergency Flashers (K6)
007 - Short to Ground - Intermittent
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 17
Mileage: 114799 km
Time Indication: 0
Date: 2012.08.11
Time: 07:25:36
Fault Priority: 2
Fault Frequency: 1
Reset counter: 29
Mileage: 116615 km
Time Indication: 0
Date: 2012.08.21
Time: 00:03:30
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 3
Reset counter: 29
Mileage: 0 km
Time Indication: 0
Date: 2012.08.21
Time: 04:02:43
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 103471 km
Time Indication: 0
Date: 2015.03.03
Time: 00:00:03
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 5
Reset counter: 29
Time Indication: 0
00446 - Function Limitation due to Under-Voltage
Fault Priority: 6
Fault Frequency: 137
Reset counter: 29
Time Indication: 0
01334 - Door Control Module; Rear Right (J389)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 103471 km
Time Indication: 0
Date: 2015.03.03
Time: 00:00:05
01333 - Door Control Module; Rear Left (J388)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 103471 km
Time Indication: 0
Date: 2015.03.03
Time: 00:00:05
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10Airbag00P H09 0018
Revision: -------- Serial number: 003DW00A8NCF
Coding: 003050
Shop #: WSC 124697 483 00190
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 428BFF0FD58FD85FF1-8016
Serial number: 3572SRB40000A6B0E908
Serial number: 3582SRB40000A3346AD8
Serial number: 3516GRB402H9DB9KPK1S
Serial number: 3526GRB402H9DB9KOCEX
Part No SW: 6R0 920 960 C HW: 6R0 920 960 C
Component: KOMBI H03 0205
Coding: 440200
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
VCID: 356194D394417FE744-8060
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087 D
Component: GW-K-CAN TP20 0207
Coding: 002100
VCID: 70EF65C7A3A31ACF57-8024
3 Faults Found:
01309 - Power Steering Control Module (J500)
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 29
Mileage: 116615 km
Time Indication: 0
Date: 2012.08.21
Time: 18:41:24
01320 - Control Module for Climatronic (J255)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 103471 km
Time Indication: 0
Date: 2015.03.03
Time: 00:00:02
03075 - Parallel Parking Assistance Control Module (J791)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 103471 km
Time Indication: 0
Date: 2015.03.03
Time: 00:01:54
Component: IMMO H03 0205
Serial number:
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADB77AF8D7FE01F19-803E
Part No: 6R0 423 156 A
Component: LenkhilfeTRW V275
Coding: 10150
Shop #: WSC 00000
VCID: 2E53BBBFED174C3F05-807A
Part No SW: 1K0 035 186 AN HW: 1K0 035 186 AN
Component: Radio RCD310 042 0082
Revision: 01000001 Serial number: VWZ1Z2N1409233
Coding: 05000400020013
Shop #: WSC 35110 377 00143
VCID: 72EB6FCFADAF28DFA1-8026
2 Faults Found:
00872 - Bass Speaker Rear Left (R15)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 188
Mileage: 0 km
Time Indication: 0
Date: 2014.11.08
Time: 13:33:01
00873 - Bass Speaker Rear Right (R17)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 188
Mileage: 0 km
Time Indication: 0
Date: 2014.11.08
Time: 13:33:01
End-------------------------(Elapsed Time: 02:04)--------------------------
www.Ross-Tech.com
Coding: 0000031
Readiness: N/A
Revision: --------
Coding: 08BC30
Coding: 08BC30
8 Faults Found:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 17
Mileage: 114799 km
Time Indication: 0
Date: 2012.08.11
Time: 07:25:36
Fault Priority: 2
Fault Frequency: 1
Reset counter: 29
Mileage: 116615 km
Time Indication: 0
Date: 2012.08.21
Time: 00:03:30
Fault Priority: 2
Fault Frequency: 3
Reset counter: 29
Mileage: 0 km
Time Indication: 0
Date: 2012.08.21
Time: 04:02:43
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 103471 km
Time Indication: 0
Date: 2015.03.03
Time: 00:00:03
Fault Priority: 3
Fault Frequency: 5
Reset counter: 29
Time Indication: 0
Fault Priority: 6
Reset counter: 29
Time Indication: 0
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 103471 km
Time Indication: 0
Date: 2015.03.03
Time: 00:00:05
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 103471 km
Time Indication: 0
Date: 2015.03.03
Time: 00:00:05
Coding: 003050
Coding: 440200
Coding: 002100
3 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 29
Mileage: 116615 km
Time Indication: 0
Date: 2012.08.21
Time: 18:41:24
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 103471 km
Time Indication: 0
Date: 2015.03.03
Time: 00:00:02
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 103471 km
Time Indication: 0
Date: 2015.03.03
Time: 00:01:54
Serial number:
Coding: 10150
Shop #: WSC 00000
2 Faults Found:
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 188
Mileage: 0 km
Time Indication: 0
Date: 2014.11.08
Time: 13:33:01
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 188
Mileage: 0 km
Time Indication: 0
Date: 2014.11.08
Time: 13:33:01
