6C GTI. Defrost Flap Motor failing/clicking.
Evo
Drives: Polo GTI 6C DSG
Post by Evo »
Hi guys. Just after some info on the best way to remove the flap motor so I can have a look at ever a replacement or a fix. So far I’ve just pulled the cable on it as it sounds like a tiny elf is hitting the windscreen with a hammer every few seconds.
I have run Vcds flap learning sequence but it only cures it until I turn the car back on.
Even to get the the cable to unplug us a massive ballache and very tight. I have taken as much as I can out from the glove box side but still can’t work out a way or see any fixings for the motor.
Any help?
Or even better is someone knows the part number already?
Many thanks guys.
