BCM Max Transporter 2013
Shadow109
Drives: Vw t5.1 2013
Re: BCM Max Transporter 2013
Post by Shadow109 »
hello Fernando, I have connected the wire for backup lamps,(T73b/12 to T10o/3)
https://drive.google.com/file/d/16-E3Nl ... sp=sharing
https://drive.google.com/file/d/1TBKLix ... sp=sharing
but I have a fault in VCDS and backup lights doesn't work
do I need to change something in the coding ?
Friday,28,May,2021,12:43:03:10253
VCDS Version: 21.3.0.0  HEX-V2 CB: 0.4543.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZDH036544   License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 37 3C 5F 65 77 0B
VIN: WV1ZZZ7HZDH036544   Mileage: 225530km-140137miles
3C-Lane Change -- Status: Malfunction 0010
Address 01: Engine (J623-CAAA)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GF    HW: 03L 907 309 M
   Component: R4 2,0L EDC   H44 3312
   Revision: 26H44---    Serial number: 00000000000000
   Coding: 01114012232400080000
   Shop #: WSC 02736 790 50316
   ASAM Dataset: EV_ECM20TDI01103L906019GF 003002
   ROD: EV_ECM20TDI01103L906019FG_003.rod
   VCID: 75B7E8FE5543B673AC5-8020
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0110
   Revision: 00H43001
   Coding: 508724AD89A70A9B24A79175796210
   Shop #: WSC 02736 790 49152
   VCID: 3A2D3BC23C5D190B817-806E
   Serial number: 11031913470358
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5F7D26075F52BFDF-802A
   Part No SW: 7E5 907 047 BM    HW: 7E5 907 047 BM
   Component: Climatic-T5   H20 0505
   Revision: 00001010
   Coding: 0000000002
   ROD: EV_ClimaT5Basis.rod
   VCID: 7BA3FEC67367E003DA1-802E
   Revision: B9084001    Serial number: 2502 306190145
   Coding: A8A0393E4E21201201280ED06EAB9ED4F08063FF608C2040320400030800
   Shop #: WSC 12345 123 12345
   VCID: 2D07009EFD13BEB3145-8078
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 230916 03  37  0059
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3313
   Subsystem 3 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3313
3 Faults Found:
01758 - Bulbs for Brake Lamps
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 42
                    Mileage: 225534 km
                    Time Indication: 0
                    Date: 2021.05.28
                    Time: 22:41:08
00901 - Back-Up Lamps
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 42
                    Mileage: 225534 km
                    Time Indication: 0
                    Date: 2021.05.28
                    Time: 22:41:07
01504 - Bulb for License-Plate Light (X)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 42
                    Mileage: 225534 km
                    Time Indication: 0
                    Date: 2021.05.28
                    Time: 22:41:07
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39331817601496
   Coding: 0001155101
   Shop #: WSC 21890 003 104857
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: EV_EPHVA18VW364GP00_VW32.rod
   VCID: 372B22F60FCF04637E9-8062
1 Fault Found:
12718592 - Databus
          U1121 00 [009] - Missing Message
          [Steuerger‰t f¸r Lenks‰ulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 42
                    Mileage: 225534 km
                    Date: 2021.05.28
                    Time: 22:41:08
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag003 H07 0013
   Revision: --------    Serial number: 003HL00DDD0.
   Coding: 000000000000000000000000000000003033
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750_VN75.rod
   VCID: 353728FE15C3F6736C5-8060
   Part No SW: 7E0 920 970 N    HW: 7E0 920 970 N
   Component: KOMBI         H04 0805
   Coding: 160A01
   Shop #: WSC 02737 790 50316
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
   Revision: B9084001
   Coding: 042204
   VCID: 6889B18A12715B9B273-803C
   Part No SW: 7E0 857 511 F    HW: 7E0 857 511 C
   Revision: AA001001
   Coding: 010100E200000100000000
   VCID: 2D07009EFD93BEB3145-8078
   Component: IMMO          H04 0805
   Serial number:
   VCID: 6A8DCB820CFD698B317-803E
Address 37: Navigation
Cannot be reached
Address 3C: Lane Change (J1086)       Labels:. 5Q0-907-686.clb
   Component: HRE_Master    H12 0080
   Serial number: 0466413079
   Coding: 02031102
   Shop #: WSC 09003 957 00200
   ROD: N/A
   VCID: 3D2730DE2DF32E33A45-8068
No ASAM data for: "EV_HREntryHella" (VN75)
2 Faults Found:
336901 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 42
                    Mileage: 225534 km
                    Date: 2021.05.28
                    Time: 22:41:08
530190 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 42
                    Mileage: 225534 km
                    Date: 2021.05.28
                    Time: 22:41:08
   Component: MU-S-ND-ER    H41 0478
   Serial number: VWZAZ2U1668085
   Coding: 0645000FBE00000011110001010D08001F0303D401200100CE
   Shop #: WSC 00046 123 12345
   ROD: EV_MUStd4CTSAT_VN35.rod
   VCID: 2517F8BEA56386F3DC5-8070
   Data carrier:
   Subsystem 1 - Part No SW: 5NA 919 866 AL    HW: -----------
   Component: MRM1 2020/21  --- 1420
2 Faults Found:
          U1101 00 [009] - Active
          [Anti-theft protection - component protection active (0xEA6300)]
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 42
                    Mileage: 225534 km
                    Date: 2021.05.28
                    Time: 22:41:08
                    Voltage terminal 30: 13.9 V
0001 - Antenna 1 for Radio
          B1119 13 [009] - Open Circuit
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 42
                    Mileage: 225534 km
                    Date: 2021.05.28
                    Time: 22:41:09
                    Voltage terminal 30: 13.8 V
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
   Serial number: 30000000047437
   ROD: EV_RDKBERU30_005.rod
Address 77: Telephone
Cannot be reached
End----------(Elapsed Time: 01:31, VBatt start/end: 13.9V/13.9V)-----------
I have checked the old and the new wire is alive when I put the reverse gear
The 3 faults detected in the BCM have one point in common, the T10o connector.
:lol:
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
ciclo wrote: Thu May 13, 2021 5:46 pm We need a Russian friend to tell us what this means...
It is the first time I see such extra title on the BCM label.
Futhermore it is not in Russian, it is in Ukrainian "Made in Germany". At first glance I thought it is a fake title. But maybe it was a special BCM series for Ukrainian market....
Updated. Asked one seller in Russia, he really has some 7E0937090E units with that Ukrainian title, but not on everyone. Also he has some 087 BCM units for sale with such title.
It also seemed somewhat disturbing to me ... at first I thought it was another one of those fantastic Russian jokes ... :lol:
Thank you very much Aleksandr for the explanation regarding the language used in that place of the BCM.
I send you a big hug with all my affection!!! I have remembered you many times ... and I also remember a lot of times about those delicious Russian gifts 🤤 that I received from you. I will be eternally grateful.🤗
Shadow109
Post by Shadow109 »
this is the seller I bought form him if anyone is interested, he seems to have a lot of these BCM 8)
dnoermann
Drives: T5.2 and Polo 9N3
Post by dnoermann »
Interestingly with those Units from Ukraine you still can learn Wireless-Key via Adaption Channel.
This Channel was disabled starting with SW 0762 ....
https://forums.ross-tech.com/index.php? ... ost-212462
firegrafik
dnoermann wrote: Fri Oct 22, 2021 10:35 am Interestingly with those Units from Ukraine you still can learn Wireless-Key via Adaption Channel.
I suppose that problem could be if the BCM has EEPROM paramatrized for Kessy , in that case BCM's internal remote module disabled permanently, that's why there is not possible to adapt the remote keys with the BCM. Moreover that issue could be not only with 7E0937090D/E unit but all 7E0937090_ and 7E0937190_ units despite the last letter.
All units from Russian sellers, as I know, parametrized for regular remote keys (without kessy) and I've never seen if someone has problems in remote keys adaptation.
dnoermann
Post by dnoermann »
firegrafik wrote: Fri Oct 22, 2021 11:19 am I suppose that problem could be if the BCM has EEPROM paramatrized for Kessy , in that case BCM's internal remote module disabled permanently.
Interesting, which address in Eeprom, and which values are Kessy parameters ?
firegrafik
dnoermann wrote: Sun Oct 24, 2021 7:50 pm
I don't have a definite answer. But I have some thoughts about it. I suppose VagCanPro could help. It has service procedure called BCM PQx5 Programmer. It shows all known parameters in the BCM's EEPROM with descriptions which also could be read, edited and written separately or as an array. I am not sure there is only one parameter concerning Kessy in the EEPROM is different.
So if you find the car with the same BCM (HW SW) as your without Kessy, read out its parameters set fully through the VCP and load it to your BCM - it will be high possibility to have the remote module to be enabled.
Below is screenshot of mine expirience in working with VCP's BCM PQx5 Programmer while I searched the reason of LED DRL not working in position light mode on my LED headlights.
Shadow109
Post by Shadow109 »
New Cluster :D
Transferring rings From the T6 housing
Updating SW :-
https://www.youtube.com/watch?v=Cn-u5m ... e=youtu.be
Shadow109 wrote: Wed Dec 01, 2021 8:08 pm New Cluster :D
8)
It looks great the T6 IC, thanks for sharing your improvements/jobs, a VW T5 with a lot of equipment.👍👌
Shadow109
Post by Shadow109 »
viewtopic.php?p=588216#p588216
Nice steering wheel Fernando 👍
I have all wiring done before, I was hoping After activating that the horn will work locking and unlocking
Thanks! my new steering wheel on the 6R is Awesome.
I do not understand if you are asking a question ...
However,
BCM
Byte5 Bit7 ... must also be enabled ... ✅
Unfortunately for me, I don't understand anything from your second screenshot, sorry ...
Shadow109
Post by Shadow109 »
I was wondering if I can activate horn confirmation when locking and unlocking the car, after searching around I think it’s possible only on MQB
In our PQ25 it is also possible (checked in my 6R), although from your comments I suppose that only for those who have an anti-theft alarm.
I'm just telling you that this is not related to the installation of the multifunction steering wheel and the ways to send the signal from the horn-plate to the BCM.
