Variable luggage compartment floor
shaunreynolds
Drives: 2011 1.6 TDI
Post by shaunreynolds »
Hi all,
New to the group!!
I've a 2011 1.6 TDI but it is missing the Variable luggage compartment floor.
Have seen lots of what i think is the right part on ebay but just wanted to make sure with the plethora of knowledge that is out there.
As far as i can tell the part number is 6R0 858 855 B S07.
Is this the right part number???????
Just to be clear... the shelf i'm after makes the whole of the luggage area level when the seats are down :D :D
Thanks in advance
FFA76
Drives: Polo 6R BlueGT
Re: Variable luggage compartment floor
Post by FFA76 »
Your correct!
According to ETKA it's 6R0 858 855 B(1BS).
wolfie
Drives: 6R1-1.2 TSI (2011, CBZB, 77Kw, 35Kmiles)
Post by wolfie »
The floor doesn't become absolutely flat with the raised boot floor in place, but it's as good as. There is a little step-up as it crosses the back of the folded down seats. Nothing much just 20mm ish.
I'm sure you'll will have checked but you will also need the LH & RH support brackets if they are not already fitted.
6R0 858 855 B 1BS (Anthracite)
6R0 858 855 B 1B (Black)
6R0 858 847 VAG (LH)
6R0 858 848 VAG (RH)
N90969901 (Fasteners. M6 X 25mm, Hex socket heads) X 4
shaunreynolds
FFA76 wrote: Tue Apr 27, 2021 5:54 am Your correct!
Many thanks!!
shaunreynolds
wolfie wrote: Tue Apr 27, 2021 5:29 pm The floor doesn't become absolutely flat with the raised boot floor in place, but it's as good as. There is a little step-up as it crosses the back of the folded down seats. Nothing much just 20mm ish.
Fitted with... thanks for the info!!
