I'm looking to get rid of the huge arch gap and seen these 2 seem to be a good budget option. Has anyone had experience with either of them? its a daily so i dont want to be spending a fortune on coilovers if i can get away with springs.
I dont mind the odd scrape on speedbumps but still need a bit of practicality and not make it undrivable.
Additionally, any advice on spacers? id be keeping the stock 185/60/15 for now.
30/50 springs vogtland/H&R?
- Platinum Member
Re: 30/50 springs vogtland/H&R?
On front no more than -35 mm spring with oem damper.50 looks brutal but ride comfort is horrible and your shock life, bushes, sway bar link, ball joints will fail faster.
- mirceaculita
- Drives: 6R 1.2TDI 75hp
how low would a reasonable lowering kit be?
- Platinum Member
35 mm in front with oem shock. Back is ok 50 mm. If you want lower and to have it all by PS you would need a sport shock or coilovers.
- Drives: 2014 Bluemotion Tech
think i'll probably go with 30 front 50 rear for now. coilovers are a bit of a stretch at the moment.
- Platinum Member
That will be all okay and good.
