6C dogbone mount differences
Post by 2226 »
Does anyone know what the difference is between the dogbone mount for the 1.2TSI (CJZD) and 6-speed (02U) transmission setup and other dogbone mounts used on the 6C?
The CJZD + 02U combination indicates the following part numbers:
6Q0 199 851 AS
6Q0 199 851 AN
I have been considering the Vibra-technics dogbone mount for a while, but this is listed to replace the following mounts:
6Q0 199 851 AK
6Q0 199 851 AQ
6Q0 199 851 AR
6Q0 199 851 AJ
6Q0 199 851 BD
6Q0 199 851 AM
6Q0 199 851 AP
6Q0 199 851 C
6Q0 199 851 AT
6Q0 199 851 H
Most of these seem to vary in the bracket only.
So I'm thinking it can't be just the mounting bracket on the dogbone mount for the AS/AN variants.
Is it a difference in the length then?
I went out to the local part store on Saturday, but they had none in stock to compare to.
