Mart!n-GTI-DK wrote: ↑Tue Jan 12, 2021 7:52 pm Hey Ciclo. Am I so lucky that you happen to know which mal and female pins I need for the plug fra the A pillars to the front doors in the mk7?
https://www.uk-polos.net/viewtopic.php?p=575519#p575519
LEVEL SENDER G76
- Blue wire to T73a/23
- Black wire to T73a/22
- Brown wire to T73c/57 ... (ground)
FCM J745
- CAN convenience
Driver door ... 4 high green-orange , 5 low brown-orange
TIUL black ... 6 high green orange , 11 low brown-orange
- CAN extended (many devices here, slightly saturated :)))
TIUL black ... 12 high grey , 13 low brown-orange --> new splice-->T2 connector: H grey-black , L white-black
Connect to new T2 connector ... H black , L white-black
- CAN headlights
Direct connection
grey-orange ... high
brown-orange ... low
- Positive +30
TIUL black ... '8' or 9 new red-black wires.
- Negative -31
brown ... ground point.
NEW FUSES (Wires: red 2.5mm, red 2.5mm -/> 0.5mm x2, white x2: 0.75mm )
- whites (+15 headlights, SC 36 and 37) ...From 123...to 7.5A x 2
Headlights white wires. Direct connection.
- red (+30) 2.5mm -/> 0.5mm x2 ...From 120...to 10A
TIUL black ... '8' and 9 red-black.
- red (+30) 2.5mm ...From L128...to *30A
Any TIUL 16 slot connector , choose the most easy to work in the future.
8IU LED HEADLIGHTS *Automatic headlights control. (cut T46b/2 and 39 wires with the same length :)))
LEFT MX1
- Feed (low beam). T73c/5 red wire. Direct connection (isolate original)
- Sig (High beam? - SCLs? - P/S/M - BLK - DRL). T46b/2 black-blue wire. Direct connection (isolate original)
- +15. white wire. Direct connection to fuse.
- CAN, direct connection to FCM.
RIGHT MX2
- Feed (low beam). T46b/1 red wire. Direct connection (isolate original)
- Sig (High beam? - SCLs? - P/S/M - BLK - DRL). T46b/39 black-yellow wire. Direct connection (isolate original)
- +15. white wire. Drect connection to fuse.
CAMERA -A5-
- Can Extended
To new T2 ... grey-orange to grey-black , brown-orange to white-black.
- CAN ACC --> A5
ACC. 5 High white-orange , 6 low brown-orange.
TIUL brown. 9 High white-orange , 11 low brown-orange.
- +15 positive.
TIUL black 15. green-black wire.
- -31 negative.
brown ... grown point.
- Dome lights buttons (58d). T6/3 blue connector --> T73c/62 grey... splice new black wire. (Y)
Tuesday,19,January,2021,19:57:59:32438
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
Data version: 20201125 DS322.1
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW License Plate: TEST AFTER INST WIRING ON TIUL. 8IU LED HEADLIGHTS ... OK
Mileage: 34703km-21563mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 20 3C 42 44 52 5F 65
VIN: WVWZZZAUZKPCICLOW Mileage: 34703km-21563miles
Address 01: Engine (J623-DKRF) Labels:. 04E-907-309-V1.clb
Part No SW: 04C 906 025 L HW: 04C 907 309 BB
Component: R3 1.0l TFS H20 6198
Revision: D7H20000
Coding: 01190032234415082000
Shop #: WSC 00046 123 12345
ASAM Dataset: EV_ECM10TFS01104C906025L 002003
ROD: EV_ECM10TFS01104C906025L_002.rod
VCID: 290F00D8897EC92304C-807C
Readiness: 0110 0000
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 DD HW: 5Q0 614 517 AC
Component: ESC H25 0424
Revision: 00000000 Serial number: 51998000000173
Coding: 01FA6AA114202170477B060560CA2580562884E26006A4733420F00A4082430B00000012121212B835351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
VCID: 76B51BA40840D6DB59E-8022
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5G0 907 044 CF HW: 5G0 907 044 CF
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 00020003200110011005004000101022
Shop #: WSC 00028 028 00068
ASAM Dataset: EV_ACClimaBHBVW37X 006145
ROD: EV_ACClimaBHBVW37X_006_VW37.rod
VCID: 6D8734C87D161503A84-8038
Fresh air blower control module (front):
A/C pressure/coolant temperature sensor:
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 DH HW: 5Q0 937 084 CG
Component: BCM MQBAB H H40 0312
Serial number: 72007150025702
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_BCMMQB 020001
ROD: EV_BCMBOSCH_020_VW37.rod
VCID: 015F7878518EE1637CC-8054
Wiper motor control module:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 180621 043 0551
Serial number: 180705074106
Coding: 0E4DDD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 052 0107
Serial number: SBY18M08D06H04M32S34
Coding: 06A8DD
Steering Column Switch:
Subsystem 3 - Part No SW: 5Q1 953 507 HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0060
Serial number: 00000002081804401346
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 D HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0050
Serial number: 000308417318277
Coding: 0271165841
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_EPHVA2CAU3700000 009041
ROD: EV_EPHVA2CAU3700000.rod
VCID: 51FF8838C16ED1E3ACC-8004
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
Component: ACC BOSCH MQB H11 0682
Coding: 2B00678119FFC728949C810560400600000000000000000004
ASAM Dataset: EV_ACCBOSCHVW416 002008
ROD: EV_ACCBOSCHVW416_002_VW37.rod
VCID: 44D1B16C0E1C344B17A-8010
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 BJ HW: 5Q0 959 655 BJ
Component: AirbagVW21 006 0339
Serial number: 003VWR4F1CUQ
Coding: 98CCC000000000005C0000CF000800000065
Shop #: WSC 00028 028 00064
ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 094F605869BEA92324C-805C
Left seat belt tensioner:
Subsystem 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B
Component: BeltPretRevFL H37 0350
Serial number: 34169667E30071820325
Coding: 333135
Right seat belt tensioner:
Subsystem 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B
Component: BeltPretRevFR H37 0350
Serial number: 34169668E31071830145
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 002 307 18
Component: SideSensor_Df 001 0887
Serial number: 35700000000F8745C23S
Coding: 2D2D2D
Subsystem 4 - Part No SW: ----------- HW: 480 002 807 18
Component: SideSensor_Pf 001 0887
Serial number: 358000000000EC18233G
Coding: 2D2D2D
Subsystem 5 - Part No SW: ----------- HW: 480 403 107 18
Component: SideSensor_Dr 003 6149
Serial number: 3510001A729FD154210-
Coding: 2D2D2D
Subsystem 6 - Part No SW: ----------- HW: 480 403 107 18
Component: SideSensor_Pr 003 6149
Serial number: 3520001A929FD1515577
Coding: 2D2D2D
Subsystem 7 - Part No SW: ----------- HW: 480 402 306 18
Component: FrontSensor_D 003 6149
Serial number: 3550001A326704A3C63.
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 791 B HW: 5G1 920 791 B
Component: KOMBI 404 4191
Coding: 07A52A802688000801887A0D1401000000000000
Shop #: WSC 00200 935 01530
ASAM Dataset: EV_DashBoardVDDMQBAB 009058
ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
VCID: 2B03FAD08382DB33F60-807E
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 521 5388
Serial number: 09012020001767
Coding: 030100047F085700DB00025C080F00010001070000000000000000000000
ASAM Dataset: EV_GatewNF 013026
ROD: EV_GatewNF_VW37.rod
VCID: 70B92DBC6A24F8EB832-8024
Generator:
Component: 4-01-02-01-04
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 5G0 959 442 AB HW: 5G0 959 442 AB Labels: 3C8-959-537.CLB
Component: E221__MFL-MD9 H18 0052
Serial number: 39190002063230049307
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Component: J367-BDMHella H10 9070
Serial number: 9353818504
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 3G0 857 511 BD HW: 3G0 857 511 BD
Component: FLA H01 0010
Revision: AA001001
Coding: 0404000000000000000000
ASAM Dataset: EV_HighBeamAssisAU33X 001019
ROD: EV_HighBeamAssisAU33X_VW37.rod
VCID: 6B833AD043021B33B60-803E
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0519386082
Coding: 02011103
ROD: EV_HREntryHella_VW37.rod
VCID: 3D27C4886DF64583584-8068
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0519601132
Coding: 020111
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 593 F HW: 5Q4 959 593 F
Component: TSG FS 006 0246
Serial number: 0000305474246
Coding: 00150320D000048000001000
Shop #: WSC 00020 999 12345
ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
VCID: 48C9A55C3234102BFB2-801C
Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000009798407
Coding: 010000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 AA HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 131 1081
Coding: 831F0000
Shop #: WSC 12345 102 209715
ROD: EV_SteerAssisMQB_015.rod
VCID: 73B322B01B32C3F37E0-8026
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 592 F HW: 5Q4 959 592 F
Component: TSG BFS 006 0246
Serial number: 0000336638884
Coding: 00150320DE00048000001000
ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
VCID: 47CBA6603F2A1F53F28-8012
Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000009846262
Coding: 090000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 874 C HW: 3Q0 035 874 C
Component: MU-S-ND-ER 853 0891
Serial number:
Coding: 02731001FF0000005111000100880A001F0500F401200000CF
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 323DE7B4A4A88AFBB56-8066
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H52 8130
Serial number: VWZ6ZHV2691212
Data carrier:
Subsystem 2 - Part No SW: 5NA 919 866 AR HW: -----------
Component: ECE AS 20/21 --- 1430
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 30000000250801
ROD: EV_RDKBERU30_006_VW37.rod
VCID: 3431E1AC5EBC84CBA7A-8060
End----------(Elapsed Time: 01:22, VBatt start/end: 12.2V/14.6V)-----------
