Re: ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP
Posted: Sun May 19, 2019 8:44 pm
Cheap front LED fog lights with drive unit.
EDIT (08/11/2019 - DD/MM/YY)
Explanations: (email request)
Well, once I installed the LED Replica headlights, the front fog lamp function stops making sense, however, the static cornering lights function, integrated from factory in the fog lamps in our Golf mk 7.5, takes on an important relevance.
Installing the new cheap LED lights with driver units in the fog lights is quite simple, the cover/cap on the wheel arch is removed and the lamp is changed.
No special adaptation or coding is necessary, static cornering lights/fog lights will work correctly (I mean without VCDS faults) as it was factory set.
However, I preferred to configure/adapt in the BCM adaptation channels this new type of LED light as follows:
VCDS. LED fog lights with drive unit---> In blue the new values!
Address 09:
SECURITY ACCESS--> 31347
Adaptation
LEFT
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16 ...(LED Lichtmodul)
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100 ,16 ...(127)
RIGHT
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16 ...(LED Lichtmodul)
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100 ,16 ...(127)
-Static cornering lights (through fog lights, Adapt: search for static AFS)
Address 09:
Adaptation
static AFS light-Oberer Lenkradwinkel,120 °,16 (upper steering wheel angle,60º)
static AFS light-Unterer Lenkradwinkel,80 °,16 (lower steering wheel angle,30º)
static AFS light-Upper speed threshold,40.0 km/h,16 (60km/h)
At night work perfectly as static cornering lights (roundabouts, intersections, corners).
The light is super white, it is the same color as the DRLs of my Replica LED headlights.
Note:
Do not use these LED lights as powerful fog lights, although they could fulfill their function ...
There are better LED lights (morimoto) to be powerful fog lights, logically they are more expensive.
01/2024
Address 09:
Adaptation
LEFT
RIGHT
Address 09:
Adaptation
Note:
01/2024
