IMPORTANT ALL MEMBERS
All members need to read the following page The new General Data Protection Regulations 2018 (GDPR)
Failure to read and accept the new privacy policy may result in your account being deleted, so please take a quick read
The UK-Polos.NET Admin Team
Clock & Mileage LCD Fade out and In
Sinus
Drives: Polo MK3 1.4
Post by Sinus » Wed Nov 29, 2017 9:59 am
Hi Guys,
I have a 1996 Polo 1.4 L
My clock and mileage LCD ( on the dashboard ) faded out recently during a long days driving. It disappeared for a week or so but came back. However it's faded out again and obviously I need to fix it....
Many thanks
Sent from my Nexus 7 using Tapatalk
alexperkins
Site Admin
Drives: 91 Golf GTI, 01 TT 225, 67 Q7
Re: Clock & Mileage LCD Fade out and In
Post by alexperkins » Wed Nov 29, 2017 9:56 pm
You’ll probably need a new set of clocks, or have yours repaired with a new LCD
Sinus
Post by Sinus » Thu Nov 30, 2017 7:21 am
Crikey, that'll cost a bit.
Will it have to be reprogrammed for the mileage?
alexperkins
Site Admin
Post by alexperkins » Thu Nov 30, 2017 9:27 am
You can get a used set. As yours is early it might be before the immobiliser was standard too which makes it even easier
The clocks can be reprogrammed to match on mileage or you just record it had a clock change so it matches up on MOT etc.
Where are you based?
Sinus
Post by Sinus » Thu Nov 30, 2017 9:32 am
Hi, I'm in Stafford, in the Midlands. I'm sure it's an early model. Is there a way to check ?
alexperkins
Site Admin
Post by alexperkins » Thu Nov 30, 2017 9:35 am
Shame you are so far as I could’ve done it for you!
Pop up a photo of the clocks you have now. I’ll help you find a set
Sinus
Post by Sinus » Thu Nov 30, 2017 9:54 am
alexperkins wrote:Shame you are so far as I could’ve done it for you!
Cheers Alex,
Here's a photo, engine was running when I took the photo, everything else works ok.
Kind regards
alexperkins
Site Admin
Post by alexperkins » Thu Nov 30, 2017 10:31 am
Yeah thats early clocks
Next question - what kind of key do you have?
Is it cut like this
or like this
Sinus
Post by Sinus » Thu Nov 30, 2017 11:32 am
alexperkins wrote:Yeah thats early clocks
Is it cut like this
or like this
Hi Alex, it's the second one...
Kind regards Image
alexperkins
Site Admin
Post by alexperkins » Thu Nov 30, 2017 11:42 am
Ok then, im pretty sure theres no immobiliser on that key. Can you PM me your reg as final question so I can just check clock part numbers?
Sinus
Post by Sinus » Thu Nov 30, 2017 12:16 pm
alexperkins wrote:Ok then, im pretty sure theres no immobiliser on that key. Can you PM me your reg as final question so I can just check clock part numbers?
Sure Alex,
It's P215 LVT
Kind regards
alexperkins
Site Admin
Post by alexperkins » Thu Nov 30, 2017 12:27 pm
Ok, part number should be 6N0 919 910 L
Theres a few on ebay - this one is a decent price
https://www.ebay.co.uk/itm/Vw-Polo-6N1- ... Sw71xZmBrR
It should be a drop in replacement without the need for coding unless you want the mileage corrected
Sinus
Post by Sinus » Thu Nov 30, 2017 1:40 pm
alexperkins wrote:Ok, part number should be 6N0 919 910 L
Cheers Alex, that's brilliant :)
Many Thanks
