Gearbox fail 6N 085
damunk99
Drives: polo
Gearbox fail 6N 085
Post by damunk99 » Mon Aug 21, 2017 10:05 pm
Hello guys, I have a gearbox problem. Those little rollers in the bearing were thin like paper and just fall out lol
The gears look in fine condition but why would the middle row of gears wobble by hand?
There are three rows of a gears n middle ones got quite a big of play.
damunk99
Drives: polo
Re: Gearbox fail 6N 085
Post by damunk99 » Tue Aug 22, 2017 7:43 am
I think I know why there is play. Because the other half of the casing holds the gears in place.
Also did the bearing fail because I have overheated the gearbox which caused friction on the casing? I think so. Can someone confirm this.
Drives: 91 Golf GTI, 01 TT 225, 11 Tiguan TDI
Post by alexperkins » Tue Aug 22, 2017 2:42 pm
That bearing looks mullered. Either its started to break down, or has been starved of oil and has overheated
The casing doesnt look too good either. Even with a new race installed, you might find there is play there now.
damunk99
Drives: polo
Post by damunk99 » Fri Sep 01, 2017 7:14 am
How can tell is casing is bad? Can't those bearing be replaced in the casing? (the red circle one)
Post by alexperkins » Fri Sep 01, 2017 8:03 am
Potentially. It depends how it’s been pressed into the case. You’d need to press it out and go get a replacement from a bearing specialist
