Can you please help me to identify the piece to stop the leaking ??? is the one on the link the right one ? Thanks
Also is it normal that you have to remove the plastic shell on the bottom of the radiator to make it fit on the heating matrix ?
Help please ....
Re: Help please ....
The plastic shell on the matrix sometimes has to be removed. The matrix itself fits a number of different cars
Need to know your engine code please to find the seal you need
Polo 6n1 1.0 50 PLalexperkins wrote: ↑Mon Aug 19, 2019 9:36 am Need to know your engine code please to find the seal you need
Another question: I'm trying to find decent controls for the radio, is there the possibility to put a steering wheel with controls ? can I adapt a steering wheel from another model ? I read a topic about the scirocco (Scirocco Steering Wheel / Mk6 Wheel Fitting on 6n2 GTI) but I don't have the airbag. any advice ?
I read this but it has not controls and I don't know if it will fit on a car without airbags
(viewtopic.php?t=42733)
did I write the wrong code ? is what you needed ? thanksalexperkins wrote: ↑Mon Aug 19, 2019 9:36 am Need to know your engine code please to find the seal you need
Sorry, been really busy with work
The seal is N906 175 01
The whole seperator inclusive of the seal is 036 103 464 G. Febi make an OE quality replacement with part number 38773
And no, controls wont be possible regardless of the wheel. These wheels need canbus which the polo doesnt have. Better to get an add on remote like the pioneer steering wheel remote.
Thank you very much for your advices.
- Drives: 1.4
Can someone provide a part number for the crankcase breather hose?
60HP
60HP
From the breather to the air box?
- Drives: 1.4
yes the one that connects to under the airbox.
