Cornering lights polo gt bluemotion
Dtype
Drives: VW Polo 1.2 TDi HighLine
Re: Cornering lights polo gt bluemotion
Post by Dtype »
ciclo wrote: Tue Jan 23, 2018 7:59 pm I explain you, so that a BCM PQ25 can manage the DRLs (in any lamp) it's necessary that it receives the signal for its operation from the light switch, this is through the wire that arrives from the light switch to PIN 29 BCM white connector 'B'.
Your BCM doesn't have that PIN. You can check it in this image :arrow: https://i.ebayimg.com/images/g/zBcAAOSw ... -l1600.jpg
Therefore it isn't possible in your 6R.
Thanks. As Fog lights/cornering lights is managed by bcm, I thought that I can enable bit 2 from byte 23 on bcm (Cornering lights as DRL)
Thanks anyway
zach138
Drives: 1.6 TDI 6R 90HP CAYB
Post by zach138 »
Hi all.
I have a Polo 6R 60 plate with standard fog lights.
Can I enable static cornering lights through VCDS?
Or do I need fog lights who have cornering lights?
In the latter option do I need anything extra (wiring, sensor etc) other than coding?
Thanks a lot
Hello zach138, to be able to tell you exactly it is necessary that you post an Autoscan of the units of your 6R.
(I think it is necessary that you have 10 posts in the forum to be able to post it)
You don't need to change the fog lights, maybe you need some new wires, and some other part (depends on your Autoscan).
zach138
Post by zach138 »
Thanks a lot ciclo - below is my full autoscan as requested.
Yesterday I tried to activate the cornering fog lights by activating bit 6 of byte 12 on the 09.Cent Electr. System with no luck as I get a bulb dtc light on the dashboard.
Any further advice will be much appreciated.
Wednesday,16,September,2020,20:08:13:46225
VCDS Version: 20.4.2.0 (x64)  HEX-V2 CB: 0.4513.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WVWZZZ6RZBY056090   License Plate:
Mileage: 131600km-81772mi   Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 2E 44 56
VIN: WVWZZZ6RZBY056090   Mileage: 131600km-81772miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAYB)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 BC    HW: 03L 906 023 D
   Component: 1,6l R4 CR td H13 6909
   Revision: --------    Serial number:
   Coding: 00114014000500080000
   Shop #: WSC 124697 483 00190
   ASAM Dataset: EV_ECM16TDI02103L906023BC 003005
   ROD: EV_ECM16TDI02103L906023AH_003.rod
   VCID: 6889BA3D92F8925BFA3-803C
Readiness: 1110 1000
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AJ    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 230228E3417200B8C42514EB82D100821300
   Shop #: WSC 02069 000 00000
   VCID: 06559485B86C642B68F-8052
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AP.clb
   Part No SW: 6R0 820 045 J    HW: 6R0 820 045 J
   Component: Climatic       25 0660
   Revision: 00 11 25
   VCID: 35372349954A3FB3B15-8060
   Part No SW: 6R0 937 087 H    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0230
   Revision: BF046001    Serial number: 0345 196101793
   Coding: 25B029BF08E12400922000003D2B0CD00000410F60060000200000000000
   Shop #: WSC 00631 210 91765
   VCID: 42DD4895D484980B047-8016
   Subsystem 1 - Part No SW: 6R0 959 802 R    HW: 6R0 959 802 R  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  006 0912
   Serial number: KU0-KU030.06.1011032
   Coding: 08BC30
   Subsystem 2 - Part No SW: 6R0 959 801 T    HW: 6R0 959 801 T  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  006 0912
   Serial number: KU0-KU001.07.1011838
   Coding: 08BC30
   Subsystem 3 - Part No: 1K8 951 171 A
   Subsystem 4 - Part No: 1K8 951 605 A
   Component: LIN BACKUP HO  H11 9004
   Subsystem 5 - Part No: 1K8 951 171 A
   Component: VW10Airbag00A H09 0020
   Revision: --------    Serial number: 003GX004AVS$
   Coding: 003041
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACD60B5EC34404BCC7-801E
   Serial number: 3572SRB40000C31D41F7
   Serial number: 3582SRB40000C291419/
   Serial number: 3515RRB40696Q5E6BGS
   Serial number: 3525RRB405D6R0C291RE
   Part No SW: 6R0 920 961 F    HW: 6R0 920 961 F
   Component: KOMBI         H04 0304
   Coding: 440A00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
   VCID: 392F2F79B9D2DBD355D-806C
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 0230
   Coding: 002100
   VCID: 70B9D25DAAA85A9BA23-8024
   Component: IMMO          H04 0304
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6A8DC0358CF4A04BEC7-803E
   Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
   Component: SG EXT.PLAYER H13 0111
   Revision: A1001003    Serial number: 7668265792
   Coding: 010000
   VCID: 270BF9015FE65D23339-8072
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 00788
   VCID: 2F3B11217E560563FB9-807A
   Component: Radio         541 5516
   Revision: --------    Serial number: VWZZZ4J6278413
   Coding: 16000400040005
   Shop #: WSC 127395 840 08317
   VCID: 46D55485F8ACA42B28F-8012
End----------(Elapsed Time: 01:31, VBatt start/end: 13.9V/13.8V)-----------  License Plate:
   Revision: --------
   Revision: 00 11 25
   Coding: 08BC30
   Coding: 08BC30
   Coding: 003041
   Coding: 440A00
   Coding: 002100
   Serial number:
   Coding: 010000
   Coding: 11230
   Shop #: WSC 00788
Your 6R can handle the static cornering lights but you will probably need to install new power wires for the fog lights (isolating the current ones).
In the 6R, the SCLs are managed by the BCM depending on the signals received by the steering ring with G85 angle sensor.
Your 6R has ESP therefore it has G85.
Your BCM has the necessary pins to send the signals to the fog lights.
Quick check to see if your 6R has the right wires:
- If the fuse box has fuse 54, your 6R does not have SCLs on the fog lights. (Only foglights)
- If the fuse box has fuse 57, it is possible that it has SCLs in the foglights except some exceptions.
It is a relatively easy retrofit in case you have to install the new wires.
The set of wires is sold at kufatec, eBay, etc. (wiring for 6R fog lights under BCM control)
The BCM pins involved and required are:
T73a / 7 signal received from the light switch to activate the fog lights.
T73b / 9 and 10 to send the signals to the fog lights, both for fog lights and SCLs.
T73b / 11 +30 power received from fuse 57.
This is a diagram that I made a long time ago for the same circumstance at hand.
https://drive.google.com/file/d/0B2nv91 ... sp=sharing
Keep in mind that you have to physically check all the pins-wires on your 6R.
The original wires, if fuse 54, must be isolated even if they are in any of the indicated positions. (except ground wires)
VCDS
BCM
Byte12 Bit6
Byte21 Bit2 and Bit3
Some adaptations in the BCM for SCLs are possible. Check out the first page of my 6R thread to find out more. (there are several links followed where I show the topic of automatic lights)
The BCM can handle SCLs, but without the proper wires it doesn't matter how many times you try to code it.
zach138
Post by zach138 »
Thanks a lot ciclo. Your help is much appreciated.
I will start by checking the fuses and take it from there.
I will definitely come back for further advice if needed.
