SOLD!
- Drives: Amarok
Re: SOLD!
Hello. I have a Vw Amarok with 086M Bcm. I tried to put a 7H0937090D and it is not communicating with my instrument cluster. I have mounted oem bixenon lights with led drl. I have mounted new wires from pin 10 to the Bcm for the drl led. Is there anyway to work this bcm in my car (communicate with the instrument cluster) and to modify the wiring so the led to work?
090B bcm also work with bixenon?
Thank You! Sorry to write here, but Amarok have the same electrical system with Polo.
Re: SOLD!
Hello georgenis, welcome.
Please read this topic in its entirety (5 pages with images). viewtopic.php?f=56&t=70736#p528319
Please don't reply there to not mix the T5 with the Amarok.
You will have to do something similar but not exactly the same, ...for that, open a new topic in the 6R / 6C section of the forum.
If you are willing to collaborate with images and information (Autoscan, etc) from your Amarok I will give you my help so that your bi-xenon headlights work correctly.
The correct BCM is 7H0937090D.
- Drives: Polo 6R
Re: SOLD!
Hello ciclo
I have polo 2011 VIN WVWZZZ6RZCY509024 with dimming mirror and rain sensor (don't know if it have light sensor included ... I have lights & vision package) number of sensor is 1K0 955 559 AH,
I have also fog lights + Daytime running lights + bend lightning
I would like to have automatic lights + LH CH if possible.
BCM number is 6R0 973 087 K
Could you please tell me if it is possible to have it without BCM replacement?
Wojtek
Wojtek
Re: SOLD!
No that won't be possible; your BCM 087 does not support it.
- Drives: Polo 6R
Re: SOLD!
Hi
Thanks for info. And what about rain sensor? This number have also light sensor i cluded?
Re: SOLD!
The rain sensor is fine, that will work without a problem. It's the BCM that is your main concern. You'll need to replace that and wire it accordingly to have the benefits of automatic lights.
- Drives: Polo 6R
Re: SOLD!
Ok now it's clear thanks. And normalny what BCM number will be correct for me?
Re: SOLD!
7H0 937 089 x
7H0 937 090 x
7E0 937 089 x
7E0 937 090 x
x being nothing or A-Z, depending on what's available and what suits your car (carrier frequency etc)
7H0 937 090 x
7E0 937 089 x
7E0 937 090 x
Re: SOLD!
Hello
Im planning on upgarding to BCM max and OEM bixenons, I desperately need the necessary looms, I do not have my car with me as of now I shall be able to provide all the details and scan results to you.
Just wanted to confirm if you are still selling these?
Re: SOLD!
Hello ciclo!
I have 2011 VW Polo GTI with halogen headlights.
The last week I bought OEM LED with Xenon headlights. (Parts number: 6R1941031C 6R1941032C).
My current BCM's part number is "6R0937087H".
I saw other "BCM modules" for buy in the internet but I don't know if it will work for my car. (7H0937089F or 7H0937090B).
I want to add a cruise control and auto headlight swicth but all this in the ''right way''.
Any suggestion?
Thanks you for your time.
Any suggestion?
Re: SOLD!
Hello Bakis
7H0937089F BCM Max will do the job. (CCS, Autolights, Xenon)
Obviously you have to make modifications to the original wiring for the lights on your 6R GTI.
There are several threads on the forum that can inspire you.
The recommended for your new BCM Max could be this: viewtopic.php?f=56&t=68980#p514546
I no longer provide personalized help on these matters, everything is written in the forum.
If you have specific questions once you have done the wiring installations you should open a thread in the corresponding section.
(provide me the link to that thread by private message)
