☼ POLO 6R. WIRING LOOMS. Automatic lights. BCM Max. ☼ ...CLOSED!
Locked
Re: ☼ POLO 6R. WIRING LOOMS. Automatic lights. BCM Max. Light Assist. ☼
danikd wrote: Wed May 30, 2018 7:25 am Thx for info.
its possible to install only autolights harness, without max BCM adaptation? Original autolight is primary reason to do it ...
No :lol:
danikd wrote: Wed May 30, 2018 7:25 am because china non-original autoheadlight works "strange" ...
Yes :lol:
danikd wrote: Wed May 30, 2018 7:25 am BCM max retrofited ( only the 3 errors ), from factory there was 086B BCM ...
Only? ...the most important errors when BCM Max is retrofited.
Actually they are more errors/faults, but your VCDS did not detect them (BCM coding, etc, etc). :lol:
You must feed the BCM (T73a/63 and T73b/68) with a +30 signal (Battery-fuses-BCM) and add wires from the BCM to the lights with intercalated fuses (OEM way).
Currently, an important part of the lights of your Citigo go through the light switch exclusively, so they can not be managed by the BCM for automatic lights. As simple as that.
danikd
Drives: Citigo
Post by danikd »
Hello, thx for info ...
iam very busy now, so someday in summer I will make documentations and start topic ... hope we will make it :)
For the present thank you very much and hava a nice day.
DAniel
danikd
Drives: Citigo
Post by danikd »
Goog morning!
I was thinking whole evening and finally, i will make it much sooner. At weekend I will try to make photos of relays, fuse box, light switch and make my own thread.
BTW VIN is TMBZZZAAZDD615614
Iam very interested in your harness - hope you help me.
If it will be working, than I make some review on german/czech Citigo/up! forums and i will be interesting for you. As thanks for your great work.
Nice day!
Daniel
Ok, good to know.
I will help you, everything depends on you. :wink:
danikd
Drives: Citigo
Post by danikd »
Hello ciclo,
all done, pls check
https://uk-polos.net/viewtopic.php?f=56&t=71456
and let me know what else I/you need for it. Or what I have to do ... Thx a lot. Daniel
Angelsman
Drives: 2011 1.2 6R
Re: ☼ POLO 6R. WIRING LOOMS. Automatic lights. BCM Max. ☼
Post by Angelsman »
Hey Circo,
Can you make me a loom adaption please? Or atleast point me in the right direction. How can I PM you?
Im looking for the trip harness so I can add a trip button stalk for DIS to my polo 6r se.
I believe it looks like this (the harness on the right)
Hello Angelsman, welcome.
:arrow: https://uk-polos.net/viewtopic.php?t=65096#p489673
Buy all three wires at your VW dealership, eBay, etc... Part number: 000 979 009 E
They have the correct ternimals on both ends.
Angelsman
Drives: 2011 1.2 6R
Post by Angelsman »
Just buy three of the same wires yeah?
Thanks for the reply
hmm... yes.
Angelsman
Drives: 2011 1.2 6R
Post by Angelsman »
ciclo wrote: Tue Jun 26, 2018 4:27 pmhmm... yes.
Hi Circo, I cannot PM you so this is the only way to contact you so apologies for bumping the thread with junk.
I have a 2011 midline cluster (i believe) with no trip button. If I swap the stalk for one with trip, install the three wires between stalk and clocks and then code my clocks will be capable of this function? Nothing else matters?
I think the PM function will be enabled after you reach 10 posts.
A suggestion we usually make is to introduce the vehicle in question, maybe we can have some mutual inspiration from the cars we have.
I'm sure there will be some questions and compliments and responding to that will surely make you reach 10 posts before you know 8)
Angelsman wrote: Fri Jun 29, 2018 4:40 pm Hi Circo...
Who is Circo? :lol:
iichel wrote: Fri Jun 29, 2018 5:53 pm I think the PM function will be enabled after you reach 10 posts.
+1
BTW, I don't answer private messages for technical support, everything that I write must be shared in the forum, so ...
I hope everyone understand it, thanks.
Angelsman
Drives: 2011 1.2 6R
Post by Angelsman »
ciclo wrote: Fri Jun 29, 2018 7:37 pm
Who is Circo? :lol:
+1
My apologies I did not mean to write your name wrong 😇.
My vehicle is a polo 2011 6r 1. 2 se 70.
Yes, it'll be capable. They are the only requirements.
Please Angelsman, from now make your questions in the forum section dedicated to :arrow: 6R/6C, thank you very much.
hmthakur
Drives: Polo gt tsi 1.2 dsg
Re: ☼ POLO 6R. WIRING LOOMS. Automatic lights. BCM Max. ☼ --- NOT FOR SALE
Post by hmthakur »
What type of pin is required in wiring loom no 3
T73 a 40 & 41?? Pins in my loom are smaller and not fitting properly
Locked
