Gt conversion
NickGt
Drives: Gt/G40 coupe
Gt conversion
Post by NickGt »
Spec includes:
Engine has done 91k
Port and polished head, done 25k from new
Chipped ecu
Air filter induction kit
G40 inlet manifold
Gearbox is a fully conditioned box that's done 35k
I've really looked after this engine with an oil change every 5k so you'll find the oil is clear without any particles at the bottom of the sump.
I will also be selling the front brake set up to go with it.
Looking for £350 all in, collect from Manchester (willing to post if you pay the courier charges)
If you'd like to hear how it runs I've got a video I can send you.
Bad bits:
will need a GT thermostat housing, but senders will be same as lower spec models.The oil senders in lower spec models will be the same too so you can swap them over to the GT engine.
will need an mpi fuel pump too but will be able to run it on an spi one if you doesn't thrash it all the time.
Will need a GT header tank too, spi don't have level sensor in and a 3 pin two speed radiator fan
If you haven't got gt clocks, I have a mate with some for sale for £10
