Noise from trunk
Posted: Sat Sep 15, 2018 10:05 pm
by claudiohi
Hi guys
I purchased my Polo TSI (Highline), and I noticed a noise coming from the trunk. I tried to check the spacer, triangle but they all look OK.
Has any colleague had problems with the noise coming from the trunk of the car?
Thanks.
Re: Noise from trunk
Posted: Sat Sep 15, 2018 10:17 pm
by TElwoody
What kind of noise, have you checked in the boot for the spare tyre, jack and stuff. Without specifying it's hard to diagnose.
Posted: Sun Sep 16, 2018 12:49 pm
by albob
I would suggest taking everything you can out of the trunk (boot) and see if the noise disappears....
Posted: Thu Sep 27, 2018 1:32 am
by neomer
I had this annoying noise too, it`s like something like plastic/rubber scratching right? If it is, that's an easy fix...
Get some of those felts with glue on the other side and put it on the metal frame of the trunk where two little rubber sticks touch when you close the door, a small piece will do. These guys are the responsible for this noise, you just need to put enough felt to avoid the rubber sticks from touching the metal directly.
Posted: Thu Sep 27, 2018 10:16 am
by RUM4MO
They use something like that under the bonnet (hood) where the rubber buffers contact the bodywork.
