H8 fog lights change for LED
peter007
Drives: Polo GTI 2018
Post by peter007 »
Hi guys, did anyone manage to change fog lights to LEDs? I have GTI with full LED lights and its very annoying when the corner light turns on... I want to buy a set of Osram or some other brand H8 LED but I’m afraidn that it still will show fault... what do you think?
The same with turn indicator in the back, I will try to change it to LED today and we’ll see...
Cadwest
Re: H8 fog lights change for LED
Post by Cadwest »
I tried two different makes of H8 LED’s, one set from Amazon Novasight and a set of Twenty20 canbus lights and both sets activated the error message on the dash. After this I fitted a set of Osram night breaker unlimited standard bulbs that give a more of a white light and 20% increase in brightness. Let us know how you get on.
Cadwest
Post by Cadwest »
Deleted
peter007
Post by peter007 »
Cadwest wrote:I tried two different makes of H8 LED’s, one set from Amazon Novasight and a set of Twenty20 canbus lights and both sets activated the error message on the dash. After this I fitted a set of Osram night breaker unlimited standard bulbs that give a more of a white light and 20% increase in brightness. Let us know how you get on.
Installed these Neolux which is produces by Osram. Error appeared. I will try to see if there is a possibility to change coding in VCDS to make it LED. I know that in Golf’s and Octavia’s it was possible.
peter007
Post by peter007 »
Regarding rear turn lights and reverse lights, all of them show error as well... though it looked very nice...
MattHGR
Drives: GTI+
Post by MattHGR »
Does OBDEleven not allow you to program the car to accept led bulbs?
peter007
Post by peter007 »
MattHGR wrote:Does OBDEleven not allow you to program the car to accept led bulbs?
No idea, I dont have this, I will see in vcds on monday ;)
reyonalmighty
Drives: Polo SE 2018
Post by reyonalmighty »
peter007 wrote: Sat Feb 09, 2019 7:59 pm Regarding rear turn lights and reverse lights, all of them show error as well... though it looked very nice...
What bulb did you use for your reverse light? They look really nice.
