Just Got my new Polo and the valeting was pretty p*** poor! Got them to re-do it but there are still areas with the residue from the covering!
What's the best way to remove it?
How to remove sticky residue on new car?
- Drives: Polo SE 1.0 TSI 95PS
Re: How to remove sticky residue on new car?
Autosmart Tardis. You can get it on eBay Stick it in a sprayer and then spray the residue on a cloth and wipe off gently.
Literally just collected ours and it's exactly the same round the door handles and C pillars..
My brother is a detailer (will be giving my car a freebie!) and I think one of the products he uses is Autosmart Tardis (tar and glue remover). Might be trade only but there are plenty of other T&G removers available.
If your car has been prepared as bad as I know they can be, then I'd probably try and find a local detailer to give it a full decontamination and wax. Or even a full correction if they really butchered it..
Edit: Ashleyman beat me...
Thanks both, I'll give it a try.
Tardis isn't trade only, I've got.
But I don't think anyone has mentioned diluting it.
You've got to dilute it, it's powerful stuff!
You're not supposed to dilute Tardis. It's best used neat.Andy Beats wrote: ↑Mon Mar 18, 2019 9:17 am Tardis isn't trade only, I've got.
Even if you did dilute it, Tardis is oil based so would separate from the water and sit on top.
Really?
Prior to buying it, every detailing website I saw said to dilute it.
It smells to high heaven, I'd worry about using it neat in case it melted plastics!
Interesting. I just had a quick google of 'Autosmart Tardis dilute', and every single result said to use it neat.Andy Beats wrote: ↑Mon Mar 18, 2019 10:36 amReally?
I've used it plenty of times neat and its fine. Obviously common sense needs to be used on where to spray, not to let it dry out etc... but I've never had a problem with it. Spray on, leave for a few minutes and rinse off, if required spray a microfibre and wipe down.
Cool, I'll give it a go neat.ashleyman wrote: ↑Mon Mar 18, 2019 10:43 am
On the Polo it doesn't matter, but the wife's car (Sportage) has plastic trim on the sills and arches.
Naturally, tar congregates most just above these trims.
Is it OK to use tardis near these trims?
