So far it’s great. Just want to drive about trying different setups. Big step up A6 C7 second generation and more basic digital setup in Golf R I tried
Thanks for the replies. I won’t be getting my Polo to June the earliest, haven’t had a build date yet I’m more expecting it in July/August time so I got a long wait to experience the digital dash.
It is geat Only thing I miss is more customization. Like I want to see water and oil temperatures, remaining range and date. It is not possible to show them all at once. Also date is not showing almost at any time -_-
Dark_cze wrote: ↑Sun Apr 14, 2019 7:12 am
You can put up more info on the media player screen on "Car", cycling through the display types. I like to put mine to the 3 circles showing boost pressure, kW output and oil temp., while leaving the drivers display as "driving information " with the display of speed and revs on 2 simulated dials.
No interest in water temp once the oil is warm, unless you worry about overheating.
I know about that but then my android auto with waze is hidden water temp is not that much important but i like to watch it rise then wait for oil and then have some fun I would like to have all important information neatly in rows like summary and not scattered all around
my current setup is:
left dial - remaining range
middle - oil temperature
right dial - audio track or consumption
media player - waze/spotiify
I love it. It's not quite the same system in my Ibiza but it's basically the same thing. I have average MPG on the left, range on the right, and in the middle I often change it up! On the motorway I tend to have the ACC display up as I like to keep an eye on it, but it 'minimises' to the bottom if you change it to something else. I keep it on regular round dials as I find them easier to read than the other options.
I would definitely spec it if I was ordering a Polo. It's cool to have the map in the display but the factory satnav isn't anywhere near as good as Google Maps over Android Auto, so I've only used it once in the month I've had the car. If they could get Android Auto to work in the dash that would be amazing! The TT has it so it must be possible, although in the TT it's effectively in a 'window' as they're not designed to work on anything other than rectangular displays.
Not with Android Auto, at least in Seat's version. It just says 'Android Auto' with a USB logo for the audio, and if you put it to the navigation bit it'll say 'Navigation on mobile device' or something like that.
TBH it doesn't bother me. I don't have anything audio or nav in the dash, just on the main infotainment screen. The routes from Waze and Google Maps are just so much better than anything else that it's worth it!
