Guys I’m looking for a favour has anyone got this on there polo as I’m looking to get scans if poss to help out in my next mod quest.
Any help would be massively appreciated
Scott
Anyone have Park Assist and vcds?
Re: Anyone have Park Assist and vcds?
Is your car a 6C as in your profile, or the current version?
If it is the previous 6C version, then you should have posted in the other section, I have VCDS and a 6C Polo with front/rear parking sensors factory fitted.
Profile updated!!!
This is for my 2018 AW and it’s Park Assist where the car parks itself.
Scott
Scott
That will be a total pain to do. Park assist requires additional sensors to the normal front and back sensors. There's an additional one each side in front of the front wheel arch.Scotty_boy vw wrote: ↑Fri Aug 16, 2019 9:34 pm Profile updated!!!
Scott
It's a total gimmick option anyway. I'd safe yourself the expense.
- Drives: 2018 Polo SEL
If your reversing into a space and the car behind has it's wheels on the kerb, your park assist will want to park in the same position, so it will start trying to climb the kerb, not a good idea for alloys .
- Drives: Polo GTI 2022
I have it fitted and haven't used it once.
Can you send the coding of this mod, cause i need it alsoScotty_boy vw wrote: ↑Fri Aug 16, 2019 9:34 pm Profile updated!!!
Scott
Thank you for your reply.
I have a problem. The ABS module coding of Scotty ir totally different that mine. I dont want to change all... i need the right information.
What bytes and bits must change?
XAGICO tutorials modules are differents.
Any ideas?
Any ideas?
