Does any one no of you can display short term mpg on active info display? Only seems to show long term???
Active info display
Re: Active info display
If it's the same as the previous Polo, press the OK button to toggle between long term, since refuel, and since start.
***EDIT*** Or more likely as monkeyhanger said as I was posting this
Sorted thanks [emoji1360]
- Drives: Her Polo R. Or my car.
I've adjusted the alternative screen views 2 and 3, but every time I select parameters to display on the LH and RH dials it never saves my selection.
I can see that the default View 1 is preset, but expected View 2 and View 3 to be available for 2 drivers to show their choices.
Seems View 2 and View 3 are alse preset. But not to what I want.
Seems odd. Or am I missing a SAVE button somewhere.
Honest. I've read the manual and spent time poking the dashboard many times.
- Drives: AW GTI with MT
I might remember it wrong since I setup my dial more than year ago.Boxerboy wrote: ↑Thu Mar 12, 2020 8:30 pm I've adjusted the alternative screen views 2 and 3, but every time I select parameters to display on the LH and RH dials it never saves my selection.
There was auto/classic/view1/view2/view3 buttons. Auto and classic was preset and no way to change them and views1/2/3 whould be user presets. I changed view 1 to whatever I liked most and than pressed media or app connect button to go back to screen I ussualy use. I don't think there is save button.
Hold down on the view 1 ,2 or 3 when you set your Desired display setting it will turn yellow and save view 1 ,2 & 3
- OomStu_ZA
- Drives: 2019 VW Polo GTi
Ahhhh, thanks for that tip will try it once we out of lockdown.
Interestingly if you have no NAV from facotry there only 2 additional views for the AID, not 3, but makes sense to me all the same.
