Rear brake noise on reverse
Chat about your 2018+ AW model Polos here!
Adeyfred
Drives: GTI
Post by Adeyfred »
Anyone else got this? Engage reverse and on movement sounds like a bloody cow mooing!
Car is booked in end of October....seem to remember a thread on this a while ago..🤔
Re: Rear brake noise on reverse
Adeyfred wrote: Tue Sep 29, 2020 9:20 pm Anyone else got this? Engage reverse and on movement sounds like a bloody cow mooing!
There's about 5 threads on this - so pretty much everyone with a GTI/GTI+ has the issue. Don't hold out hope for a proper fix.
Drives: GTI+
Wouldn't waste your time taking it in mate.
S_94 wrote: Tue Sep 29, 2020 9:51 pm Wouldn't waste your time taking it in mate.
Agree. And as has been said before, as braking efficiency isn’t affected, VW are unlikely to consider this a high priority in terms of implementing a proper fix.
Adeyfred
Drives: GTI
Post by Adeyfred »
Ahhh!...cheers guys for the replies👍
I won't hold much hope then!🙄
Andy Beats
Drives: Polo GTI DSG with upgraded 18" wheels
Post by Andy Beats »
Text from the wife this morning, she was still in bed when I left.
"what's that noise your car made when you were reversing"
:roll:
SuperNaz1980
Drives: GTI Plus
Post by SuperNaz1980 »
Hi All,
Just joined, as found some of the articles very interesting including this one.. I've recently purchased a VW Polo GTi. I have the same issue when reversing, the brakes makes a squealing sound, especially when parked for a long period. The first dealer I took my car to, they said it was due to the brake pad material used by VW. I contacted VW and they said that's not true. Getting a second opinion from another dealer now. Just booked an appointment for December so quite far away. They said they will need to strip the brakes and inspect. They aren't aware of manufacturing issue and suspect due to glazing?? or they maybe able to solve by adjusting the ABS control. Will let everyone know of the findings. Thanks.
Naz
PoloGtIM7
Drives: Polo GTI mk7
Post by PoloGtIM7 »
Hi Naz / Everyone
bought my Polo GTI+ Brand new waited 12 months for the build and collected it on 21/12/2019 and on 17/02/2020 it went in for same problem as everyone else is having. sounds like a bloody cow is making sounds in the back of my car lol they changed the rear brake pads and the sound went away for around 2 months and now the sound is back but this time 100x worst. the car went back in on the 02/11/2020 and I've just been told VW are now aware of the problem and there is currently no remedy for repair
Has anyone else got anymore info on this problem ?
I am in the process of filing for rejection under the consumer rights. but of course i dont want to lose the £6k deposit I put into my car does anyone know how i stand ?
Thanks Louie
Andy Beats
PoloGtIM7 wrote: Fri Nov 06, 2020 11:40 am Hi Naz / Everyone
Thanks Louie
You're not going to like this, but your chances of rejection are more or less zero. :(
For starters, you've had the car for 11 months....
Rejection is easy for 30 days, still relatively easy for 60 days and then gets progressively harder.
I know all of this because I was recently going through rejection of an Evoque that was in the garage every week for the first 5 weeks we had it for a serious fault.
For seconds, you say it went into the garage on 17/2 and 2/11, so that's only two days off road.
That's nothing.
Thirdly, a noise during reverse isn't exactly a serious fault that prevents you using the car, or a safety issue.
Your case for rejection is so weak as to be pointless....sorry. :(
You clearly dislike the car over and above the brake problem as it's nowhere near serious enough to ruin it (and my car makes the same noise and yes it's annoying).
So maybe you just need to bite the bullet and sell it or trade it in.
Perhaps the dealer will do you a deal seeing as you're pee'd off with it.
Drives: GTI+
A member of the forum wayne10244 has explained this problem in more detail. If the noise is annoying you that much, his advice is to change your pads to a softer compound. See here: viewtopic.php?f=71&t=75354&p=574761#p574761
EBC yellow stuff pads are recommended by him.
Two months into ownership and my GTI+ has been pretty much moo-free. There’s just been a hint of a very subdued mooing noise on a couple of occasions:- when using the car after I’ve washed it and there’s been the usual post-wash coating of light rust on the braking surface of the discs.
Apart from that, no mooing brakes, although I’ve probably tempted fate now by saying that 😀.
Andy Beats
Mine moos really loud every morning.
But seeing as it's only 10 feet a day, it's not something I'm going to take time off work to go to the dealer about.
I may mention it when it goes in for the knocking tailgate, I wish that only happened 10 feet a day....
