LED kit Rear lights 2G1052200 coding
Chat about your 2018+ AW model Polos here!
MicheleMelluso
Post by MicheleMelluso »
Hello,
I have installed the OEM rear lights kit (2G1052200). I have read the instructions in which it says that they must be coded with a SVM code 4061A by ODIS. I don't have Odis but I bought OBDEleven. Can I coding them with OBDEleven to remove lights errors?
Sorry for my English
UPDATE:
This is the orinal retrofit coding for the OEM rear lights led
Last edited by MicheleMelluso on Tue Nov 03, 2020 3:19 pm, edited 1 time in total.
ho8882000
Drives: 2019 (AW)
Re: LED kit Rear lights 2G1052200 coding
Post by ho8882000 »
MicheleMelluso wrote: Wed Oct 21, 2020 10:00 pm Hello,
I use VCDS, not OBDEleven, but maybe this can help you:
https://www.uk-polos.net/viewtopic.php?t=75470
MicheleMelluso
Thanks for the reply.
With those settings I fix the errors of the lights, but do I have to change other settings? for example the Dimming of the lights.
Is there anyone who has the original factory fitted LED taillights that can kindly send me the values of these Electric 9 ECU adaptations ?
Leuchte20BR LA70
Leuchte21BR RC8
Leuchte23SL HLC7
Leuchte24SL HRA69
Leuchte26NSL A65
Thanks again.
ho8882000
Drives: 2019 (AW)
Post by ho8882000 »
MicheleMelluso wrote: Sun Oct 25, 2020 1:25 am Thanks for the reply.
Leuchte20BR LA70
Leuchte21BR RC8
Leuchte23SL HLC7
Leuchte24SL HRA69
Leuchte26NSL A65
Thanks again.
Cool... :D
I don't think you need to change other settings, but it is better that you can get the original factory adaptation setting of the LED taillights and compare.
My Polo don't have LED taillights, so you have to wait and see if other forum members can help you.
MittyAhmed101
Drives: Polo Beats
Post by MittyAhmed101 »
Where did you get the adapters from and i have both genuine led rear lights but not the coding instructions or the adapters any advice would be appreciated
MittyAhmed101
Drives: Polo Beats
Where could i get the adapters and coding instrucyions from, i have bought 2 rear led genuine mk6 polo aw lights.
Anyone who could please help, greatly appreciated.
MittyAhmed101
Drives: Polo Beats
Where could i get the adapters and coding instructions from, i have bought 2 rear led genuine mk6 polo aw lights.
MicheleMelluso
Did you buy the kit or just the headlights?
MittyAhmed101
Drives: Polo Beats
Hi, i bought just the tail lights from a breaker polo r line
Just found out that they need wiring adapter and coding.
MicheleMelluso
These are the official instructions https://www.kunzmann.de/produkt/tuning- ... 171117.pdf, instead 1K8972928B is the code of the two connectors you need to replace.
MittyAhmed101
Drives: Polo Beats
Hi, could i buy the wiring harness / adapter from volkswagen dealership / vw parts.
Also, can i code these lights using obd eleven instead of odis. As i have obd eleven that plugs into obd port.
As i have both led rear lights, all that's left is wiring adapter and coding.
Thanks 😊
MittyAhmed101
Drives: Polo Beats
Hi, which is the adapter that is required for these rear led lights
1K8 972 928 C as it's right hand drive in uk
Also, would obdeleven be good enough to code them in
MittyAhmed101
Drives: Polo Beats
Hi, I've ordered the connectors, what do i do with the new and old connectors, is it a simple swapping the connectors.
Or do i need to add wiring as well
If someone could please help with explaining this wiring connection that would be great
MittyAhmed101
Drives: Polo Beats
MittyAhmed101
Drives: Polo Beats
