Engine sound when pulling away 9N
- Drives: Polo 2004
Hi All
Stupid question, but would I be correct in thinking that as the engine on my daughters 1.2 Polo is a 3 cylinder, when you pull away from stationary, it starts off sounding like a diesel? It sounds for a short while as if the plastic under stray is loose but its not. If you rev the engine in neutral, there is no noise at all, only under load.
As I say, its a stupid question but compared to the daily BM we drive, its a different animal
Andrew
Andrew
- Drives: 53 plate Polo 9n
Re: Engine sound when pulling away 9N
Hi there,
Yes, the three cylinder engine is a little diesel-ish in sound. Even the newer Polos that are 3 cylinder are rather 'raspy'.
Regards,
C.
Regards,
C.
- Drives: Polo 2004
Thanks for confirming that
Andrew
Andrew
- Drives: Polo 2004
Managed to find time today to video the noise that I am referring too.
Its a 9N 1.2 16V 2005 engine and only done 80k miles
If you blip the throttle quickly at low revs or when pulling away slowly you get this noise but also I can feel it through the pedal. Its not, but it sounds like under tray vibrating.
I am wondering with such movement with the engine tipping as to how the exhaust copes. Are both engine mounts shagged or is this normal
If you rev its slowly, its quiet and very smooth as can be seen in one of the clips
https://youtu.be/rq0jv91XHcc
https://youtu.be/Sc1uwLcyzmY
https://youtu.be/Wj38V4Y6WEI
Any help and comments appreciated
Andrew
Andrew
- Drives: Polo 2004
Bump
Thank you
Thank you
- Drives: Polo 2004
How much should the engine rock when revved or when pulling away?
Thank you
Thank you
A little but not a huge amount. If you can rock if when the engine is off relatively easily it’s a sign the engine mounts are past it
- Drives: Polo 2004
Thanks Alex
- Drives: Polo 2004
I need to look at this again as its a pain.
I have replaced the lower rear engine mount and all seems to look OK but to be honest, not being too familiar with the car, I could do with some suggestions
When you pull away, especially from cold, it feels like the there is either loose trim or engine transmitting through the bodywork only in the drivers front corner. You can feel it through the body shell as if something is touching. When I say touching, its like the exhaust is vibrating under the floor but in the front corner only and improves when warm or the engine is hot. Cant see exhaust touching anywhere. It has done this now for many months and hasn't got worse, just embarrassing when pulling away as you can clearly hear it outside of the car.
Could it be:-
Bumper fixing, but then again why would it be worse when cold?
Water pump bearing? Would there pump quieten down when warm?
possibly the drive belt tensioner spring as I can see the belt has polished the top of the sump or whatever it is under the bottom pulley although the local garage said that was normal. Do they wear and become sloppy?
I'm thinking the fact that it seems worse when cold must be a clue
When cold, you can hear something vibrating or transmitting noise when its just ticking over
Engine I think is in great shape as it doesn't lose water or use oil
Any other suggestions much apprenticed
Thank you
Andrew
Could it be:-
Thank you
Andrew
- Drives: Polo 2004
Engine sound when pulling away 1.2 9N
Hi All
Been having a look at noises from the engine offside area
This is done with ease using a bar, but should the mount be this soft and low down?
https://youtu.be/hDv2Hg-Mhhs
https://youtu.be/x5dNmevJUh0
Also, when i look a the belt, it has or is touching now and then as can be seen by the shiny patch below the pulley, would this be a stretched shiny pulley or the tensioner? Cant feel any play by hand on the tensioner and I suppose if the coil spring has broken, it would allow play and very noisy
https://uk-polos.net/download/file.php?mode=view&id=454
Any feedback or advice appreciated
Andrew
Andrew
That is a horrible noise!
These engine mounting are very compliant so I'd think that they are okay.
The shiny bare metal area - I'd think that you should be concentrating on working out why that has been happening and stopping it.
Sorry no more ideas!
- Drives: Polo 2004
Thanks for quick response
Presume the belt can either be stretched as its very very shiny or the tensioner has weakened. There again, I'm not convinced a tensioner with that sized spring can weaken. That only leaves a soft or stretched belt, can't be anything else surely.
Although then engine mount is captive rubber and may not be knocking, a soft one would surely allow the engine to rock more and even the exhaust movement would be affected etc
The mounts appear a reasonable price Borg and Beck I have seen for £35'ish on ebay so maybe worth replacing anyway, not sure
Thanks again
Andrew
Thanks again
Andrew
I'd only expect the exhaust to touch the body under certain sudden engine loading conditions as the drive train will flex in its mountings in reaction to its load change.
For instance, I had the front flexi replaced by a proper exhaust builder - he did not get delivery of the correct size of flexi so just fitted one diameter size up and length size down, car seemed okay apart from an annoying slight resonance or other noise when driving on a level road. The next day I reversed it up our steepish driveway and the noise was terrible - okay let the revs drop too far and exhausts and drive trains do make horrid noises when labouring. In that case we failed to agree that his work was at fault as I am only a DIYer, so I bought in the correct flexi, paid him to replace it, which he still said would not make any difference - and that returned the car to being as good as new!
Back on topic, from your video clips, that noise seems to be coincident with a snap/step change in demanded engine speed - and any issues with the crank end float, auxiliary belt tensioner or anything else in that area, should still be the centre of your investigation.
Tip, with the engine warmed up, remove the auxiliary belt - then see if there are any noises, if they have gone then you know where to look - auxiliary belt or associated parts, if the noise is still there, I'd be checking the end float of the crankshaft by trying to move that bottom pulley in and out, or even check that bottom pulley.
- Drives: Polo 2004
Thanks, that is a good suggestion about removing the belt as the engine will still run, will do.
I did fit a new exhaust last year all bar the flexi pipe, will look into it
Andrew
Andrew
- Drives: Polo 2004
Ok, today finally got round to removing the belt and wow, noise gone. Presumed and replaced new belt tensioner and alternator tesntion wheel. All done and noise now back.
The air con pump seems to be the problem when I listen with a stethoscope I can here erratic knocking.
What puzzles me is that you seem to hear this noise when steering is on full lock or when youre pulling away. At low revs. Why should it do that?
Looks like it’s eBay pump and get it topped up
Andrew
Andrew
