Im planning on vinyl wrapping my centre console - fed up of the rubbery paint on it which chips and looks awful!
Anyway, I know how to take off the centre console itself but how do you remove the centre air vents (the ones above the radio)?
Are they held on by torx screws? and if so which size Torx would I need to do this? The only reason I ask is I have limited tools, only t20 and t15 torx but no others and therefore would need to get hold of them before I start taking this thing apart.
Thanks for the help!
Anyone removed the centre vents before?
- Drives: 2015 6c polo
Re: Anyone removed the centre vents before?
Hi there Take the radio surround off then if there are any screws the will be above the radio .... also you will need a hook or a puller and through the vent at the top there is 2 cut ins one on each vent where the puller locates then they should pull out at volkswagen we have a special tool for it but it is essentially just a puller dont know how well other pullers will work ...hope this helpz
Sent from my SM-G920F using Tapatalk
Hi thanks for replying.2015_polo wrote:Hi there Take the radio surround off then if there are any screws the will be above the radio .... also you will need a hook or a puller and through the vent at the top there is 2 cut ins one on each vent where the puller locates then they should pull out at volkswagen we have a special tool for it but it is essentially just a puller dont know how well other pullers will work ...hope this helpz
Generally I'm going to pull the whole centre console out which will require removal of the radio anyway. I believe the vents are stuck on the centre console somehow but not sure how.
My vents don't come out from the front. They can't be pulled out as they seem fixed to the back of the centre console?
Ok they should come out from the front but if you are taking the center console out it might be easier to get to them etc ..... good luck
Are we talking about the same polo?2015_polo wrote:Ok they should come out from the front but if you are taking the center console out it might be easier to get to them etc ..... good luck
Mine looks like the above and wont pull out the front?
Sorry i must have mis read there are screws on the top where the tray is ....there should be 2 or 3 torx screws
And it will come out with the rest of the surrounds etc
Ah ok. So how do you separate the vent from the surround after the surround has come off? Can it be done at all?2015_polo wrote:Sorry i must have mis read there are screws on the top where the tray is ....there should be 2 or 3 torx screws
Should be able to when its all of there should be tabs on the back and the vent should just be clipped in to the surround
Perfect! Thank you.2015_polo wrote:Should be able to when its all of there should be tabs on the back and the vent should just be clipped in to the surround
I'll seek more advice if I have trouble getting it off
No worries good luck
