Page 9 of 10
Re: Replacement engine
Posted: Tue Jan 09, 2018 2:49 pm
by alexperkins
Part number is 036 131 503T
which translates to:
pierberg 7.28248.17.0 (this is the original OE supplier)
https://www.ebay.co.uk/itm/VW-LUPO-6X-6 ... SwjM5aJU~m
or via amazon (febi, but its pierberg)
https://www.amazon.co.uk/febi-bilstein- ... i+%0939417
Posted: Tue Jan 09, 2018 4:24 pm
by littlepolo
Thanks. On order from eBay express delivery.
Posted: Wed Jan 10, 2018 11:52 am
by alexperkins
Keep us posted
Posted: Wed Jan 10, 2018 6:29 pm
by RUM4MO
Yup, that is the same as the one I fitted to a BBY engined 2002 Polo years ago, they seemed to have learned something about keeping the windings cooler since the original design of EGR - nice manly cooling ribs, lovely! I was certainly impressed when I replaced it on that Polo! Though maybe I'm easily impressed!
You need success, and need it soon - just in case you didn't know!
Posted: Thu Jan 11, 2018 9:19 am
by littlepolo
With a car of this age it will be a never ending story.
When I fit the new EGR should I run the engine up to temp beforehand (with the old EGR, which is currently disconnected), then swap parts over and run VCDS to adapt the new EGR and throttle body (again)? Or is it OK to swap cold and run the adaptations?
Posted: Thu Jan 11, 2018 9:24 am
by alexperkins
Do it cold and calibrate as per
http://wiki.ross-tech.com/wiki/index.ph ... Adaptation
Do not start the engine till it’s calibrated
Posted: Thu Jan 11, 2018 2:19 pm
by littlepolo
New EGR fitted and calibrated. All is well, for now.
Thanks again for your help and will post some pics of the damage I found shortly.
Posted: Sun Jan 14, 2018 10:07 am
by littlepolo
Here are some photos from the strip down and rebuild. I did not have a lot of time to document the whole story (mainly due to weather conditions).
1.4 BBY engine with the head off:
1.4 BBY engine cams worn:
1.4 BBY engine with oil pump removed:
1.4 BBY engine with oil pump from donor engine:
1.4 BBY donor engine head:
1.4 BBY donor engine valves:
1.4 BBY engine donor head fitted
1.4 BBY camshaft locking tool in place:
Posted: Sun Jan 14, 2018 10:14 am
by alexperkins
You’ll need to copy the .jpg URL. Load each img.ur image and copy the image address once it’s loaded by right clicking it
Posted: Sun Jan 14, 2018 10:55 am
by littlepolo
alexperkins wrote: ↑Sun Jan 14, 2018 10:14 am
Thanks.
When I copy the URL from the following image I can see it:
(this is the URL
https://imgur.com/gallery/UBvaj5V)
Posted: Sun Jan 14, 2018 12:17 pm
by alexperkins
I’ll fix them for you
Posted: Sun Jan 14, 2018 3:42 pm
by bvs
Hi Littlepolo
Any images in Imgur can be posted direct to the page using the BB code available on Imgur (copy /paste) .
Posted: Mon Jan 15, 2018 11:43 am
by littlepolo
alexperkins wrote: ↑Sun Jan 14, 2018 12:17 pm
The camshafts or the posting?
Posted: Mon Jan 15, 2018 12:03 pm
by alexperkins
The posting. The camshafts actually dont look too worn. No worse than my Mk2 Golf GTI from 28 years ago lol
Images are all fixed
Posted: Mon Jan 15, 2018 5:10 pm
by littlepolo
alexperkins wrote: ↑Mon Jan 15, 2018 12:03 pm
They might not look worn but with them and the tappets the noise was too much.
Thanks for doing the images.
