To any following this, I found what was the issue for the bad idle and the difficult start.
As Alex presumed it was a bad injector, it has a small malfunction and that causes the bad idle.
As for the heavy start, it was all because of the glow plugs it seems.
The guys at the shop recommended replacement only in both cases.
Faulty start, faulty idle 1.4 tdi
- Drives: 1.4 tdi 2004 BAY 75 HP
Re: Faulty start, faulty idle 1.4 tdi
Is there a forum post about changing an injector on this engine?
Has anyone here done this before by themselves?
