Comfort control module
somone123
Drives: 9N polo twist 1.2L
Post by somone123 »
Hi all!
I am in the process of adding remote central locking to my polo I have established how this is done (replacing the comfort control module located above the clutch pedal) but I am not sure which model to replace it with. The one I currently have is the 6QO 959 433 G and doing a quick search on ebay for 6QO 959 433(no letter) gives results with "E" and "H" on the end.
I was wondering is someone would be able to tell me which one has the remote central locking feature.
Thanks in advance!!
Grazuncle
Re: Comfort control module
Post by Grazuncle »
Hi Someone123
I too am trying to do this modification.. but.. I can see where the box should go above the Clutch pedal..
https://www.dpreview.com/galleries/7292 ... ct-removed
help..anyone?
Wen I have this information I'm going to do a YTube video and hopefully this would help someone else :)
Grazuncle
Post by Grazuncle »
Many thanks for your fast reply..
I have seen this information before :)
I'm still not sure how you get the 'old' one out. From my photo it seems to be inside a holder but can't see plugs etc. Apart from the removal over the heater ducting I can't see how you do this job and no one seems to detail it enough (for me anyway.. :) is the casing around the existing unit removable perhaps?
The controller I have has two sockets.; one larger than the other. My CCU was off an identical Polo 9N3.. year/model etc so I'm hoping it should work as others have said/done.
I have the flip key cut ( from a photo!) and am using my original transponder; this works fine in the locks and starting the engine.
any more help is much appreciated :D
Grazuncle
Post by Grazuncle »
Hi again..
I'm posting a photo to hopefully jog someones memory on how to get the old Unit out and get the CCU in
https://www.dpreview.com/galleries/7292 ... ccu-unit-2
The old unit Blue spot.. seems to be inside a case.. Red Line
I removed the heater ducting and the switch over the clutch pedal. This is driving me nuts.. I'm inches away from using the new unit but stumped.. I agree access is very restricted.. on person said it 'was a bit of a headache' to remove but I can't see any way to get it out.
Help, please?
many thanks
Stephen
Drives: 9n3
Post by Stephen »
Hi
Did you manage to do this ?
I’m about to do it too - and like you the instructions seem light on this bit, so do the online workshop manuals.
Lying on my back in the footwell - I can’t even see it. At the moment the only plan seems to be to start removing trim until it appears!
Any help and or lessons learned would be welcome ...
