Wiper motor stops in middle of screen
reeflodge
Drives: 2003 Polo 1.4 16v
Post by reeflodge »
When I turn off the window wipers they stop in the middle of screen.
They do clean the whole screen when switched on but always park in middle!
Is there a relay or fuse that may be causing this?
They are not loose on the spindles.
Re: Wiper motor stops in middle of screen
As it sounds like they are wiping through the correct arc of movement, I'd think that the problem is inside the wiper motor assembly, if you are able, open that up and take it from there.
reeflodge
Post by reeflodge »
Yes it cleans the whole screen but just stops in middle of screen when turned off.
Is there not a relay or fuse for this or is it the motor?
Is the motor easy to remove?
Is it repairable?
This thread should be locked as the OP has created another thread covering this topic!
