I have a polo 9n 1.2 e 55 bhp. I changed the air filter and knocked off a vacuum line, turned the engine on and it was idling rough and brake pedal was stiff.
I opened the bonnet and found a rubber tube had fallen off, replaced it and all was fine. Once I checked again when it was light outside, the pipe which connects it is split. I believe it is some sort of vacuum line but I am struggling to find one online to replace it.
There is a part number but I cant get the exact part
6Q2 612 041
Thanks!
Brake vacuum line
Re: Brake vacuum line
There are a wide variety of versions of this part. You need to speak to the dealer or TPS and get them to lookup your reg against this part number and they can provide the last two letters which will identify the one you need
