Error code P0301 Solved
Aybesea
Drives: Polo 9Ns 1.2 AZQ 2003 Reflex Silver
Post by Aybesea » Sat Jul 27, 2019 4:46 pm
Had this error code P0301 come up on my scanner so i took the plug out of No1 cylinder looked ok but cleaned it and also the coil pack.After putting them back on i started the engine and no error code but the engine still misfired.So i took the No1 and 2 coil pack off and put a multimeter across both of the outside 4 pin connectors on No1 and No2 coil packs,got a reading on No2 of .38 but zilch on No1coil ,headed off to Eurocar parts and replaced the coil pack for No1,also got a set of sparkplugs and new air filter.fitted it all and all is ok now Hoora :)
