My rear passenger brake caliper is seized so need to replace , eurocarparts list 34 mm or 38 mm . any idea which mine is , the car is 2004 1.4 tdi reg is cfo4fwc ?
what size please brake caliper piston ?
Re: what size please brake caliper piston ?
I was always under the impression that it was an age thing and not an engine power output thing, ie a revision, but I can't think that that helps you at all.
I just got a refurbished calliper from ECP for my old Passat 4Motion and handed the old one in to get the surcharge back.
Maybe emailing BiggRed would help you a bit?
Edit:- http://www.biggreddemo.auto-guru.uk/contactus
