Polo 9n 1.2 2004 Yr Relay location to sort code 17834
Andrew S
Drives: Polo 2004
Post by Andrew S »
Hi All
Had the error code 179834 and just replaced the purge valve but after clearing the code, after a few miles, the light has come back on so my next move is the relay but where is the relay?
Any photos much appreciated as when looking on the internet, its a minefield and so much on Golfs etc
Thank you
Andrew
Re: Polo 9n 1.2 2004 Yr Relay location to sort code 17834
Hope this helps
Andrew S
Drives: Polo 2004
Post by Andrew S »
Thank you Iichel, this is very much appreciated
Are they located under the dash on the drivers side? Easily accessed?
Andrew
Bepis
Drives: 2017 6C GTi Manual
Post by Bepis »
This should help to locate the relay box but no mention of a relay for the purge valve.
Andrew S
Drives: Polo 2004
Post by Andrew S »
Thanks Bepis
Yes, it has been difficult to find things electrical for purge valve, it seems to be more related to fuel pump stuff
Andrew
