Parking Sensors
Polo_Tom
Drives: VW Polo 9n
Parking Sensors
Post by Polo_Tom »
Recently the parking sensors on my polo have decided to only work on occasion, the same goes for when I put it in reverse, the beep will only happen now and then.
I'm guessing it's something to do with a wiring connection.
Does anyone know where I'd access the wiring for the parking sensors or any other possible causes for this?
Tom
Re: Parking Sensors
First thing to work out is if this system is a VW Group system fitted at factory, or a VW workshop retro fitted Cobra system, or a 3rd party retro fitted system.
CarbonChaos
Re: Parking Sensors
Post by CarbonChaos »
Like said you will need to determine what’s fitted, but as a starting point
In the boot area take the trims off the sides and possibly the rear and trace the wiring from the sensors to a control unit ? This may give you a clue what your dealing with.
Good luck
