Temperature gauge reading
Bikergonebald
Drives: 2004 1.2 Twist
Post by Bikergonebald »
Hi guys.
I have a simple question. Does the temperature give a true variable reading?
In some cars the gauge will always point to the same place when in a ‘normal’ range and goes to the top when over temperature.
The car is a 2004 1.2 three cylinder
Kevin
CarbonChaos
Re: Temperature gauge reading
Post by CarbonChaos »
No it does exactly as you describe,normally points to the middle then goes into the red when it’s too late
Bikergonebald
Great. Thanks for confirming that.
Johntheo1
Drives: 2018 MK10 AW1
Post by Johntheo1 »
Bikergonebald wrote: Wed Jul 28, 2021 8:03 am Great. Thanks for confirming that.
As above, it will read the actual temperature up to 75C and will then rise quickly to 90C and remain there until 107C after which it will again read the true temperature.
Here are the various temperature parameters.
VW Polo (Mar.2005)
Thermostat begins opening at 84C. Fully Open at 98C.
Fan Speed 1 ON at 91C to 97C. OFF at 91 to 84C.
Fan Speed 2 ON at 99C to 105C. OFF at 98 to 91C.
