why is the timing belt tracking to the left?
Posted: Sat Sep 25, 2021 3:58 pm
by larry
greetings, changed the timing belt on bby engine , main belt is tracking to the left of cam.
https://www.youtube.com/watch?v=eX1t6doWxjw
did i incorrectly install the tensioner ?
Re: why is the timing belt tracking to the left?
Posted: Sun Sep 26, 2021 10:49 am
by littlepolo
Did the engine run after install? It will be held within track of the pulley guide/limits. Did you replace studs? It seems something is out of line, cross threaded/bent? I'd back track and refit.
Posted: Sun Sep 26, 2021 12:02 pm
by RUM4MO
I'm sure that this has been discussed in the past either here or the Skoda or SEAT motoring forums, so I'd think that it is normal and probably due to either sharing components with other engines or a design error/limitation, I certainly noticed that on my wife's previous car a 2002 BBY engined Polo after it got its belts etc replaced twice.
Edit:- it looks like you have used a Dayco main timing belt as I can see the PTFE coated inner surface - something else that has been discussed on these VW Group forums, ie "why/what is Dayco belts got on their inner running surface?" I think that VW Group use Dayco for these belts in the service packs.
Posted: Sun Sep 26, 2021 12:33 pm
by littlepolo
I always buy the Gates kit (incl w/p) and have never had a problem.
Posted: Sun Sep 26, 2021 12:46 pm
by larry
Here is the engine running
i am beginning to think that it could be the belts. why would the smaller belt track to the left ? both belts are tracking to the the left . all components used are dayco.
Posted: Sun Sep 26, 2021 12:50 pm
by larry
yes, brand new studs .
Posted: Sun Sep 26, 2021 7:06 pm
by larry
RUM4MO wrote: ↑Sun Sep 26, 2021 12:02 pm
did it track to the left more than this ?
Posted: Mon Sep 27, 2021 6:07 pm
by RUM4MO
Sorry I'd be lying if I said either way, that car was traded in in August 2015, so I've forgotten - but my initial concern was for the way the main belt did run over to one side on the toothed pulley.
Posted: Sat Oct 09, 2021 8:31 am
by Euler2
On looking at the first photo, is it just me or does it look like the tensioner retaining arm is not seated properly below the flange bolt as it seems to sit on the bolt instead of sitting below the flange bolt.
Is that the way it is supposed to be ?
Posted: Wed Oct 13, 2021 11:51 am
by littlepolo
That is how it is supposed to be. It is just an index/position marker for the assembly.
