1.2 TSI EA111 (CBZA, CBZB, CBZC) ... with GRA High ... Image
What do you think?
CNK
Drives: 6R
Post by CNK »
How does it differ from your GRA (Geschwindigkeitsregelanlage?) ? Is it with ACC?
You can see in the lower left corner MFA+ the SET Speed, also when cruise control is CANCELed, but no when cruise control is OFF.
This way you can RESume safely by knowing the set speed.
I think it is mandatory for safe driving.
My VW R-line 1.2TSI CBZC (2013) is a s**t, do not have it. :( :lol:
+ info
CNK
Drives: 6R
Post by CNK »
ciclo wrote:You can see in the lower left corner MFA+ the SET Speed, also when cruise control is CANCELed, but no when cruise control is OFF.
+ info
Ok, I understand. My friend with GTI instrument cluster had this function in 1.2 TSI 105hp.
In my ECU/engine this doesn't work. IMO this is not big feature, so don't worry! :P
Look at this :lol:
CNK wrote: My friend with GTI instrument cluster had this function in 1.2 TSI 105hp.
Would it be possible to share this information with all of us? Pictures, video, VCDS Autoscan?
CNK wrote: Look at this :lol:
It is perfect to go fishing... Image
CNK
Drives: 6R
Post by CNK »
ciclo wrote: Would it be possible to share this information with all of us? Pictures, video, VCDS Autoscan?
I'm afraid that will be impossible. He sold his 6R. He had 1.2 TSI, manual gearbox, 105KM (77kW) + chip, 2010 Highline with CCS and RNS310.
He liked speed, but the engine in his car by this began to slowly fall apart (noisy timing gears, oil spill, etc.) :twisted:
Bachecco
Drives: Polo 1.2
Post by Bachecco »
Hi ciclo, do you know what are the electric diagrams to install this botton for posterior parking sensor?
Inviato utilizzando Tapatalk
CNK
Drives: 6R
Post by CNK »
Bachecco wrote:Hi ciclo, do you know what are the electric diagrams to install this botton for posterior parking sensor?
:arrow: https://docs.google.com/document/d/1wmk ... sp=sharing
govindsharma
Drives: polo 1.2 petrol HighLine
Regarding Indian Polo
Post by govindsharma »
Dear Sir first of all thanks for replying my post.Sir my polo Indian auto scan log is as follows check it and please reply with positively.
Thursday,14,July,2016,19:47:47:33490
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0 (x64)
Data version: 20140905
VIN: MEXD16603GT082427 License Plate: NEW
Chassis Type: 60 (6RU)
Scan: 01 03 08 09 15 17 19 25 44 56
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CJLA) Labels: None
Part No SW: 03E 906 019 AQ HW: 03E 906 019 AQ
Component: SIMOS11.2 H04 1968
Revision: --H04--- Serial number:
Coding: 00110016032400000000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_ECM12MPI02103E 001001
ROD: N/A
VCID: 73E3A997DA37FA8696F-8026
No ASAM data for: "EV_ECM12MPI02103E" (VW25)
Readiness: 0000 0101
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 BP HW: 6R0 907 379 AQ
Component: ABS9.0 front H01 0003
Serial number: --------------
Coding: 60DD2763212B18C20618E46B845818000000
Shop #: WSC 00000 000 08192
ASAM Dataset: EV_Brake1ABS90BOSCH 003017
ROD: EV_Brake1ABS90BOSCH.rod
VCID: 8D175F6F5CD30C7660B-80D8
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 418F335FD80B1816D43-8014
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6RU 937 086 M HW: 6RU 937 086
Component: BCM IM M+4 H40 0432
Revision: BY040001 Serial number: 0200 078160167
Coding: 3AB02BFF48A10000013806006CAB069000C0414F608C2000200000000000
Shop #: WSC 124697 483 00190
VCID: 6BD3B1F78A0722465EF-803E
Subsystem 1 - Part No: 5K7 955 559 B
Component: RLS 311215 03 37 0059
Coding: 036800
Subsystem 2 - Part No SW: 6R0 959 802 EF HW: 6R0 959 802 EF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 020 2551
Subsystem 3 - Part No SW: 6R0 959 801 ED HW: 6R0 959 801 ED
Component: J387__TSG_BT 020 2551
Subsystem 4 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Coding: 240000
Subsystem 5 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
Component: J388__TSG_HL 019 1552
Subsystem 6 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
Component: J389__TSG_HR 019 1552
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW013KE03
Coding: 003036
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 499F2B7FE83BD0560C3-801C
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6RF 920 861 B HW: 6RF 920 861 B
Component: KOMBI H01 0215
Coding: 110800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
VCID: 4A9D1473ED3DDB4E059-801F
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 6RU 909 901 HW: 6RU 937 086
Component: GW-K-CAN TP20 H40 0432
Revision: BY040001
Coding: 002300
VCID: 193FBB3F101B60D67C3-804C
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H01 0215
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
VCID: EADD34F30DFDBB4EA59-80BF
Address 44: Steering Assist (J500) Labels: 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_SE12.rod
VCID: 418F335FD00B1816D43-8014
End ---------------------------------------------------------------------
govindsharma
Dear Sir First of all thanks for replying my post i am sending you my auto scan log please check it and suggest me regarding auto headlight,PDC and auto fold mirror.
thank you
ROD: N/A
Revision: V0000000
Coding: 036800
Coding: 240000
Coding: 003036
Coding: 110800
Revision: BY040001
Coding: 002300
Serial number:
govindsharma wrote:Dear Sir First of all thanks for replying my post i am sending you my auto scan log please check it and suggest me regarding auto headlight,PDC and auto fold mirror.
thank you
The VCDS 12.12 version always had difficulty for readings. (not in all cases)
Get another version, for example 15.7.4, which is better for your 2016 Polo.
Your BCM:
- OEM automatic lights are not possible with 086 BCM (from 089 onwards).
- I'm afraid the comfort function for auto folding mirror is not possible with 086 BCM. (I'm not sure).
Note: Your BCM (MY2016 'G' IND) should be 087 according ETKA. (maybe online ETKA is not fully updated for India)
- OPS. Check Address 19: CAN Gateway (J533) --> Installation List, the Address 10: Park/Steer Assist (J446) should be registered, then follow the vcds instructions in this guide (pg.78) for Park/Steer Assist , and Address 56: Radio (J0506) --> Coding, Long coding helper, search in Bytes that OPS is active.
onursumer
Drives: Polo BlueGT 1.4 TSI 150HP DSG
Post by onursumer »
hi
I searched but couldn't find it , do you know the part number of the r line front bumper
thx
Front bumper R-line (PR-code 2JP--->ETKA)
6R & 6C
6R0807221AC
6R0807217H... for vehicles with headlight washer system
govindsharma
Dear Sir can you please tell me how can i get my SKC code or security code for adaptation in my car.I had seen in many site that many people had said they have code like 31347 , 23366 and many other haw they get that codes.
thank you.
¿Have you tried as explained in pg. 80?
Remember, the unit is Address 10: Park/Steer Assist (J446)
Locked
