Adam87
Drives: T5.2
Post by Adam87 »
favi wrote:
Understand ;)
So, mission complete. And now? Instrument cluster high version and BCM max :)
I already have premium 3D cluster
(I'm sure possible for polo?) [emoji41] Image
Just need T6 BCM for next mods [emoji6]
favi wrote: Understand ;)
Are very good choices, when they are installed you will have the feeling of having a 6R better. :wink:
iichel wrote:
ciclo wrote: because of how stupid it is... but I will try it.
More info the next week...if I have success. :lol:
you will retrofit a DSG?
... nope :) , or better than a DSG gearbox the WRC engine (stage 4 - 400 hp), in this way we ensure that the GRA_High function is present ...Image
It is about a part that can leave you Knock Out (hmm...blocked)... What is it? :lol:
Clue 1: only one section of this part changes the color from a date. May 2010.
Clue 2: If you compare with other VW models with GRA_High function they do not have this part. (BCM PQ25 = Jetta AW0, T5/6, Fox, Gol, etc...)
Clue 3: probably YOU have to remove this part due to some retrofitting in the future. If you have CCS from factory.
Clue 4: if you use a multimeter...
(remember that this new idea is just a test, it need not be the cause of the problem for GRA_High)
favi
Drives: 6R
Post by favi »
But...
It is quite difficult to find the instrument cluster from the Polo GTI 6R.
So for now, it's time for the front bumper, PDC and headlight wash;)
New Autoscan
With:
- New ECU software
- New Steering Angle (G085)
- New RLS coding
- With K-line from T16/7 OBD2 to T94/86 ECU.
- Without speed signal from T32/9 IC to T94/21 ECU. (installed earlier :))
- Without blocking diode in wire to CCS RESume (T41/31 to T73b/46). (to iichel :mrgreen:)
... and without GRA_High...again... :lol:
Sunday,09,October,2016,13:52:24:06516
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 16.8.1.3
Data version: 20160902 DS256
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: G85 70
Mileage:    Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 77 0B
VIN: WVWZZZ6RZDY0CICLO   Mileage:
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 5466
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
   ROD: EV_ECM12TFS02103F906070FJ.rod
   VCID: 6A1782ECD7A057CC5A-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   Shop #: WSC 40308 002 104857
   VCID: 02AF52A43BA8C7F41A-8056
Address 04: Steering Angle (G085)       Labels: 6R0-959-654.clb
   Serial number: 08021613470174
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7E235A280704EF583A-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 38D9EE4617A6836ECA-806C
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Component: BCM PQ25 Max4 H80 0733
   Revision: B9080001    Serial number: 0771 100150209
   Coding: 3CB02FBF48E1240093380E917CEB9FD0DAC0672F600D30D0200000030800
   Shop #: WSC 03607 002 104857
   VCID: 68098ED6D7B6633E4A-803C
   Subsystem 1 - Part No: 5K7 955 559 B
   Component: RLS 110215 03  37  0059
   Coding: 0714DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU003041440937042
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU006031440656541
   Coding: 1000AB
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Serial number: 27140003142720054516
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU003051200017821
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010051200012315
   Coding: 18BC32
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361212601014
   Coding: 308001
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3EE3DA6807C46F183A-806A
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   VCID: 4AF7C28C570017EC5A-801E
   Serial number: 3575HRB405N1C4LI7929
   Serial number: 3585HRB405B1D5MS8GS2
   Serial number: 3515RRB405B17ABS901.
   Serial number: 3525RRB405B181TUDPKC
   Part No SW: 6R0 920 870 C    HW: 6R0 920 870 C
   Component: KOMBI         H05 0607
   Coding: 140E01
   Shop #: WSC 00233 572 91226
   ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
   VCID: 35DAE84FE3A9915BE2-8060
   Component: GW-K-CAN TP20 H80 0733
   Revision: B9080001
   Coding: 002200
Address 20: High Beam Assist. (J844)       Labels: 8S0-857-511.clb
   Revision: AA001001
   Coding: 0404001C00000000000000
   VCID: 2ED3FA38C794CFA8BA-807A
   Component: IMMO          H05 0607
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
   VCID: 2AD7022CDF60D78C5A-807E
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
   Component: RNS-MID       H06 5218
   Revision: AB001001    Serial number: VWZ6Z7L7654213
   Coding: 04000442040000A10001
   Shop #: WSC 12345 123 12345
   VCID: 37D8EC4513A38569F2-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V13  8348
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2FD0FC3D678BB5B1B2-807A
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 77186C051BE305A9F2-8022
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 3BE4E4510BD77D05D2-806E
End-------------------------(Elapsed Time: 04:04)--------------------------
hmmm you have a new vcds cable ;) at least a very recent version.
i presume it's a wire that you're hinting to me about. i'll have a dive into ELSA this week :lol:
Adam87
Drives: T5.2
Post by Adam87 »
Was worth trying and can be ruled out
I think your going to need a DSG ECU and adapt for manual
Adam87 wrote: I think your going to need a DSG ECU and adapt for manual
I do not know if that's possible.
Manipulate the ECU software (CBZC) for such conditions can be highly dangerous. :roll: :lol:
In any case it makes no sense if everyone else with a 6R can not activate the GRA_High function easily :), and the only way I know is with VCDS program or in a VW dealer.
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
This could be of interest to everyone.
The one drive2 user was able to made the VCDS autoscan of the Polo sedan GT 1,4 CZCA MT w/o ESP on the dealer's showroom
https://www.drive2.com/l/456205517379863873
Copy it here
Tuesday, 11, October, 2016, 8: 12: 44: 10463
Vasya — Windows VAG / VAS emulator
Vasya Version: 15.2.0.0
Data version: 20150227
… (Well, excuse me old John, he retired, but regularly serves) …
VIN: XW8ZZZ61ZHHHHHHHH Plate number: unavailable
Mileage: 10km-6mi repair Number: as we quietly, without repair
Chassis: 61 (7E0)
List: 01 03 08 09 10 15 17 19 25 44 55 56
VIN: XW8ZZZ61ZHHHHHHHH Mileage: 10km-6miles
01 Engine electronics — Status: OK 0000
03- Electronics brake system — Status: OK 0000
08- Electronics air conditioner / heater — Status: OK 0000
09- unit onboard power supply control — Status: OK 0000
10 Parking autopilot — Status: OK 0000
15 Airbags — Status: OK 0000
17 Dash panel — Status: OK 0000
19 Diagnostic interface for data bus — Status: OK 0000
25 alarm — Status: OK 0000
44- Power steering — Status: OK 0000
55- Corrector of headlights — Status: OK 0000
56- Radio — Status: OK 0000
Address 01: Engine Electronics (J623-CZCA) Label: Not found
   Part No SW: 04E 906 027 HT HW: 04E 907 309 BK
   Component: R4 1.4l TFS H23 3202
   Revision: R9H23 ---
   Encoding: 00190012232400000000
   Workshop #: WSC 01430 965 01200
   ASAM Dataset: EV_ECM15TFS02134E956067HT 001004
   ROD: No Information
   VCID: 7DFA15EDECD2B3D005-8628
No data for the ASAM: "EV_ECM14TFS01104E906027HT" (VW25)
Faults found.
Availability: 0110 0001
Address 03: Electronic brake system (J104) Label: Not found
   Part No SW: 6R0 907 379 BP HW: 6R0 907 379 AQ
   Component: ABS9.0 front H01 0003
   Encoding: 50DD4864212404C10A1D126F845720000000
   ASAM Dataset: EV_Brake1ABS90BOSCH 003,017
   ROD: EV_Brake1ABS90BOSCH.rod
   VCID: 0D2A354DDC59865018-8758
Faults found.
Address 08: Electronics air conditioner / heater (J255) Label: 6R0-907-044.clb
   Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
   Component: Climatronic H12 0615
   Revision: V0000000
   VCID: 4284B95DD6A116302C-8714
Faults found.
Address 09: onboard power supply control unit (J519) Label: Not found
   Part No SW: 7E0 937 090 B HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001 Serial number: 0182 127 131 476
   Encoding: 22904BFF08A1000001380601ECCB07F00EC0656F604F3940220000030800
   VCID: 2A30FEB545D6F6781D-887F
   Partition 1 — Part No: 5K7 955 559 C
   Component: RLS 140 716 04 42 0106
   Encoding: 0228DD
   Partition 2 — Part No SW: 6R0 959 801 EC HW: 6R0 959 801 EC Label: 6R0-959-801.CLB
   Component: J386__TSG_FT 023 2531
   Encoding: 000000
   Subsystem 3 — Part No SW: 6R0 959 802 EG HW: 6R0 959 802 EG Label: 6R0-959-802.CLB
   Component: J387__TSG_BT 023 2531
   Encoding: 000000
   Subsystem 4 — Part No SW: 1K8 959 442 HW: 1K8 959 442
   Component: E221__MFL-DC1 H04 0103
   Encoding: A4FFFF
   Subsystem 5 — Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
   Component: J388__TSG_HL 022 1531
   Encoding: 000000
   The subsystem 6 — Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
   Component: J389__TSG_HR 022 1531
   Encoding: 000000
Faults found.
Address 10: Parking autopilot (J446) Label: Not found
   Part No SW: 6RU 919 475 A HW: 7N0 919 475
   Component: PARKHILFE 8K H06 0018
   Revision: -------- Serial Number: 22262622202820
   Encoding: 108002
   ASAM Dataset: EV_EPHVA18VW250GP00 001002
   ROD: No Information
   VCID: 63C2399D906275303C-8134
No data for the ASAM: "EV_EPHVA18VW250GP00" (VW25)
Faults found.
Address 15: Airbags (J234) Label: 5K0-959-655.clb
   Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
   Component: VW10AirbagU05 H10 0020
   Revision: -------- Serial Number: 003GW016GCTT
   Encoding: 003 035
   ROD: EV_AirbaVW10BPAVW250_SE25.rod
   VCID: 4922A12DE894DD70F4-811C
Faults found.
Address 17: Combination of devices (J285) Label: 5K0-920-xxx-17.clb
   Part No SW: 6RF 920 861 C HW: 6RF 920 861 C
   Component: KOMBI H01 0217
   Serial Number: 00000000000000
   Encoding: 110A00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
   ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
   VCID: 4B9E2B34E2EDCF50C6-851E
Faults found.
19 Address: Data bus diagnostic interface (J533) Label: Not found
   Part No SW: 7E0 909 901 HW: 7E0 937 090
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Encoding: 002200
   VCID: 68D244B39B7B0479CB-813D
Faults found.
Address 25: Immobilizer (J334) Label: 5K0-920-xxx-25.clb
   Component: IMMO H01 0217
   Serial number:
   Encoding: 000000
   Workshop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
   VCID: 6AD13EB38D583868DD-883F
Faults found.
Address 44: Power steering (J500) Label: 1Sx-909-144-44.clb
   Part No SW: 1S1 909 144 P HW: 1S1 909 144 P
   Component: EPS_ECU H51 1702
   Encoding: 0001000000010000
   ASAM Dataset: EV_SteerAssisNSK 014,008
   ROD: EV_SteerAssisNSK_VW12.rod
   VCID: 4084BC12DBAB3C3823-8015
Faults found.
Address 55: Corrector of headlights (J431) Label: 6R0-907-357.clb
   Part No SW: 6R0 907 357 C HW: 6R0 907 357 B
   Component: AFS-ECU 005 0050
   Revision: -------- Serial Number: --------------
   Encoding: 0D4B000001000000
   ASAM Dataset: EV_HeadlRegulVWLWRCC 002,006
   ROD: EV_HeadlRegulVWLWRCC.rod
   VCID: 3A70CEF1BD8746E76D-807F
Faults found.
Address 56: Radio (J503) Label: Not found
   Part No SW: 6RF 035 184 HW: 6RF 035,184
   Component: Radio 017 0113
   Revision: -------- Serial Number: VWZGZ1S7035624
   Encoding: 00000400000010
   VCID: 030E7315824DC6206E-8076
Faults found.
End ------------------------ (Elapsed Time: 02:36) ----------------- --------
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
Parking autopilot in polo sedan?
firegrafik
benzinkopf wrote:Parking autopilot in polo sedan?
It is just translation issue. The autoscan was provided by Russian version Vcds.
Frankly, I don't know why simple Park assistant in Russian VCDS named as autopilot. It is funny.
Thank you very much FiregrafikImage. Highly interesting.
For some time I'm trying to discover the Byte24 Bit1 function, perhaps it is related to the radio.
Would be possible the BCM Adaptation channels? in a .csv file? :lol: , :lol: .
firegrafik wrote:Frankly, I don't know why simple Park assistant in Russian VCDS named as autopilot. It is funny.
:lol:
I am now immersed in a large and exciting project 8) ...together with a forum mate :wink:, so for some time will not have enought time to walk around here.
Sometimes it is necessary be transported to other universes to clear the mind.
benzinkopf
Ciclo. Before that. I was wondering for some time now that my MFSW is not 100% fully working. I still have to use Menu button on the Instrument cluster and the menu button on the MFSW is not functioning. Do you know how to get this working? Coding? Not enough wiring? Image
Menu buttons on the multifunction steering wheel only work on instrument clusters with multifunction display.
You have to change the instrument cluster.
benzinkopf
Oh i see. Thanks for ur fast response! good luck with ur new project. I'm waiting for ur mod on ACC! Pls.
7E0 BCM: Byte 22 bit 0: if on, dipped beam, parking lights and terminal 58d function in the DRL position of the light switch.
Locked
