firegrafik
- Drives: 6R 1,6MPI(CFNA) sedan
As I saw on his autoscan, 61 Battery Regulator is already unmarked in gateway. And the specific features of this unit, even it excluded from the Installation list but it active all the time because it is the part of the BCM, like Gateway (except BMT) and despite of it unmarked in gateway, the coding of 61 Battery Regulator has battery and alternator LIN regulation, and because of its absence the fault appears. So the main thing is not only exclude 61 Battery Regulator from the Installation list, but before that switch off the LIN regulation for the battery and alternator. This is possible in the coding.
firegrafik
As a rule battery /alternator LIN regulation exists on the cars with start/stop systembenzinkopf wrote:May i know in details whats the function provided by the Battery Regulator? I thot it is critical where the module can monitor your low battery level and shut down unnecessary equipment for one last engine start? I ve thought once to install the module, but I'm not sure whether the function that i want like above is there or not.
Totally agree. I made a small mistake of reading... I just woke up and I'm still having my first coffee...firegrafik wrote:As I saw on his autoscan, 61 Battery Regulator is already unmarked in gateway. And the specific features of this unit, even it excluded from the Installation list but it active all the time because it is the part of the BCM, like Gateway (except BMT) and despite of it unmarked in gateway, the coding of 61 Battery Regulator has battery and alternator LIN regulation, and because of its absence the fault appears. So the main thing is not only exclude 61 Battery Regulator from the Installation list, but before that switch off the LIN regulation for the battery and alternator. This is possible in the coding.
govindsharma
- Drives: polo 1.2 petrol HighLine
Ciclo dear good afternoon
Good afternoon too. (here, now)govindsharma wrote:Ciclo dear good afternoon
benzinkopf
- Drives: 1.2TSI 105HP DSG7
[emoji33] nice snow[emoji1360]
govindsharma
Ciclo Sir is there any chance to activate folding mirror in Indian Polo by changing any hardware or any other item please tell me.
Thanks in Advance.
Thanks in Advance.
Nothing new, recently we were doing some tests in a '14 (México) without positive results for the Auto function. It works with the coding I have posted, but after 12-14 seconds it is disabled itself when you lock the car with remote.govindsharma wrote:Ciclo Sir is there any chance to activate folding mirror in Indian Polo by changing any hardware or any other item please tell me.
Thanks in Advance.
We think it is related to instrument cluster or BCM. (cluster without MFA, 6R0 BCM).
This 6R is very similar to mine except these units.
It remains a mystery.
VIN: WVWCU46R4DY2XXXXX
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 M HW: 6R0 937 087
Component: BCM PQ25 H+4 H32 0407
Revision: BF032001 Serial number:
Coding: 3CB02BBF08F324009A3008002C2B0CD00040410F60040000200000000000
Shop #: WSC 12469 483 00190
VCID: 479DBD97F6582F26159-8012
Subsystem 1 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 K910
Coding: 0200A3
Subsystem 2 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 K910
Coding: 1000AB
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 5 - Part No SW: 6R0 959 591 B HW: 6R0 959 591 B
Component: J245 PS72.023 H02 0007
Coding: 081001
Subsystem 7 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Coding: 18BC32
Subsystem 8 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Coding: 18BC32
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 860 K HW: 6R0 920 860 K
Component: KOMBI H05 0608
Coding: 140801
Shop #: WSC 00788 648 00255
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 3C77D27BB79E7CFE88B-8069
govindsharma
Dear Ciclo is there any the difference between window regulator motor part no 6R0 959 802 EF and 6R0 959 802 EFZ02 ,Z03,Z04,Z05.Is they have different function or only part no is different and function is same.
Hi Ciclo,
Have you tested MIB 1 (Discovery Pro) units in your Polo after upgrade to 7E0 BCM?
I've tried connect a Golf 7 MIB 1 unit yesterday to infotainment can. Didn't work.
The display in the climatronic unit was just flashing as if the messages on the can-bus was totally wrong. Tomorrow I'll test with comfort can to see if it works (it properly won't work).
The screen is a 6C0 919 603 and it fits perfectly in my car
The radio it self is working perfect when listing to radio or using the navigation. It just won't turn on/off or interior lights in the buttons doesn't work - due to no communication on the can-bus. Wondering if someone has made a 'can-bus converter' just like in the old days with RNS-E in Audi...
The split Disciver pro system won't work as it MQB platform, you need the single unit Discover media as that is PQ platform,
- CNK
- Drives: 6R
Also Component Protection should be supported by Instrument cluster
@iichel probably know something more about this
Car (MQB car) should still be able to communicate with the radio. Also VCDS if you press SETUP for approx 10 seconds, enter green menu and choose to boot up to 10 times (can't remember the exact menu to choose)CNK wrote:Also Component Protection should be supported by Instrument cluster@iichel probably know something more about this
