benzinkopf wrote: Fri Oct 06, 2017 6:39 am On the light assist, No way i can proceed with that coz im still searching for the highline cluster and learning proper tool to do the swap. worst case now, no more new cluster from aliexpress. i’m stuck there for now. [emoji27][emoji17]
viewtopic.php?f=56&t=58703&start=3615#p524635
viewtopic.php?f=56&t=58703&start=3615#p524657
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
ciclo wrote: Sat Oct 07, 2017 5:52 am
am I the lucky person who get an offer for the unused cluster? :shock: :lol:
NO, that new Instrument cluster is mine.
Image :lol:
Read again the whole page, and draw your conclusions.
benzinkopf
haha. at first. i thot you re pointing me to the availability of the product from aliexpress. but as of now, n from the my location. i cant find one. [emoji17]
yes, you can. :lol:
Fabio_89
Drives: Beetle 2.0 TSI
Post by Fabio_89 »
ciclo wrote:
Fabio_89 wrote: Fri Oct 06, 2017 6:23 am
ciclo wrote: Tue Aug 27, 2013 8:43 pm New mod:
Rear footwell lights
Hi Ciclo,
First, Congratulations for you Polo, amazing car!
Well, see if you can help me.
I own a Beetle 2.0T TSI with 06R 937 088F BCM
I wanna to install footwell lights (front and rear, but mostly in front) but i don't know if it is supported by that BCM and where to Pin it.
Do you have that information ? I saw in you post about rear positions (positive 65A and negative 4A, right?), but how about front lights ?
Hope you can help me
(sorry about my english, i'm from Brazil)
Thank you
Hi Fabio_89, welcome.
I hope you understand the following diagram:
My recomendation.
- Uses LED lamps.
- Connect to any point on the indicated wires (never near of the BCM connectors). The challenge to overcome is that these two wires are the same color for the Beetles.
The reference to follow are the pins of the dome lights.
In this way, by connecting the power to the wire going to T73a/65 and ground to the wire going to T73a/4 your footwell lights will work when opening the door.
The diagram is from the Beetle. (except my horrible sketch)
Thank you!! The diagram is perfect
So, it is not possible to pin direct into BCM like Polo, right?
Enviado do meu iPhone usando Tapatalk
OEM-way
The above diagram is exactly the same like the Polo 6R (e.g my footwell lights), all footwell lights connected to the BCM. (The BCM controls these two wires as you can see in the diagram)
On the other hand, the Beetle can have ambient lights (speakers, door trim) via 58d signal and :arrow: this dimmer. (the middle one)
Non OEM-way
The footwell lights can be connected individually, I mean each footwell light with its corresponding door (but without BCM control).
I don't provide support to do this... :lol:
benji58
Drives: 6R R-Line 1.2 TDI
Post by benji58 »
Always amazing mods !! 8)
What is the next step? GRA high? front assist? :lol:
Fatigue Detection (MKE), just to inform.
...in short, take a brake!
- Fatigue: extreme tiredness resulting from mental or physical exertion or illness.
- Information fatigue: impairment caused by excessive information. :)
:mrgreen:
Image...ooor maybe in some adaptation channel of our 7E0 BCM-Gateway?
In any case, I am not sure that this function is effective to me, I already born fatigued. Image
benzinkopf
activating is one thing. even if activated.how to test? driving till fatique? 🤣
benzinkopf wrote: Tue Oct 10, 2017 12:05 am activating is one thing. even if activated.how to test? driving till fatique? 🤣
:) ... a new menu - Assistants - will be enabled with this function.
http://www.vwwatercooled.com.au/forums/ ... 95634.html
VCDS. SRI Reset 'POLO 6R' . IC software higher than 0607. (MFA+)
Due to the software update that I did recently - from 0607 to 0705 or 0709 - apart from the oil change service (long life or not) there is a new Inspection service, which has to be adapted according to distance, time and oil quality. (flexible intervals for inspection).
This Inspection service can not be reset in the adaptation channels (at least in my IC with the new updated software) as was done with the oil change service in IDE00342-ESI: Resetting ESI, Reset - IC adaptation channel, nor by setting the correct values on the two appropriate channels (to 0).
- IDE03351-FIX: Distance covered since last mileage-dependent inspection,
- IDE03352-FIX: Time since last time-dependent inspection,
I tried with these two channels, but my IC continued with the inspection warning. Maybe it's because it was the first time this change was made, it really should have cleared the warning with these two channels set to 0.
To be able do this, we first have to set the correct parameters/values in the IC adaptation channels according to the time, distance and oil quality (good quality oil).
The following values are an example.
They are the ones I have set in my 6R to clear the Inspection service warning from the MFA+ screen. When I perform the oil change service (30000kms) I will adjust the values correctly.
IDE00301-Distance,28030 km,2
IDE00342-ESI: Resetting ESI,Reset ,1
IDE00492-MAS00900-ESI: Coding of Service Interval Extension (SIE)-Oil level,Oil level evaluation ,1
IDE00492-MAS02003-ESI: Coding of Service Interval Extension (SIE)-Status ESI or SID,ESI or SID on ,1
IDE00492-MAS02006-ESI: Coding of Service Interval Extension (SIE)-Selection of ESI or SID,Extended Service Intervals (ESI) ,1
IDE00492-MAS02010-ESI: Coding of Service Interval Extension (SIE)-Oil pressure,dynamic oil pressure ,1
IDE00492-MAS02011-ESI: Coding of Service Interval Extension (SIE)-Remote clock receiver,without remote clock receiver ,1
IDE00492-MAS02012-ESI: Coding of Service Interval Extension (SIE)-Oil quality,good oil quality ,1
IDE00492-MAS02013-ESI: Coding of Service Interval Extension (SIE)-TOG,Oil level thermal sensor connected to instrument cluster ,1
IDE00510-ESI: distance driven from inspection,28000 km,2
IDE00511-ESI: time from inspection,400 d,2
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km,2
IDE00514-ESI: maximum value of time between inspections,744 d,2
IDE00515-ESI: oil quality,good oil quality ,1
IDE00517-ESI: soot entry,0 km,2
IDE00518-ESI: thermal load,0 km,2
IDE00827-ESI: minimum value of time between inspections,372 d,2
IDE03349-FIX: Max. distance until next mileage-related inspection,30000 km,2
IDE03350-FIX: Maximum time until next time-dependent inspection,744 d,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,28000 km,2
IDE03352-FIX: Time since last time-dependent inspection,400 d,2
IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km,2
IDE05932-FIX: Reset value for next time-dependent inspections,744 d,2
And secondly you have to do what is shown in the video:
When perform the SRI for both services will appear the symbol --- Km-mi / --- days in the MFA line of oil change until several kilometers-miles have been made.
New IC
6RD 920 870 A
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H04 0805
Coding: 140E01
Shop #: WSC 00233 572 00000
VCID: 47E0D47D231B3DD55E-8012
Wednesday,11,October,2017,12:54:52:06516
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.8.0.1
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: NEW IC
Mileage: 28110km-17466mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 65 77 0B
VIN: WVWZZZ6RZDY0CICLO   Mileage: 28110km-17466miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 5466
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
   ROD: EV_ECM12TFS02103F906070FP.rod
   VCID: 6A0F8AD4DFA86FC066-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   Shop #: WSC 40308 002 104857
   VCID: 02A75AAC33B0DFE826-8056
   Serial number: 08021613470174
   Coding: 01
   ROD: EV_LWSKLOVW25X_VW25.rod
   VCID: 7E1B62100F0CE75406-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 38D1F64EEFAE9B62D6-806C
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 122170091
   Coding: 3CB02FBF48E32400B3380F916CEB9FDCDAC0672F600D30D0200000030800
   VCID: 2BCC0C29DB6FD5897E-807E
   Component: RLHS 220816 0  42  0106
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU003041440937042
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU006031440656541
   Coding: 1000AB
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Serial number: 27140003142720054516
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU003051200017821
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010051200012315
   Coding: 18BC32
Address 10: Park/Steer Assist (J446)       Labels:| 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361212601014
   Coding: 308001
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3EDBE2500FCC671406-806A
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   VCID: 4AEFCA745F082FE066-801E
   Serial number: 3575HRB405N1C4LI7929
   Serial number: 3585HRB405B1D5MS8GS2
   Serial number: 3515RRB405B17ABS901.
   Serial number: 3525RRB405B181TUDPKC
   Coding: 140E01
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 002200
   VCID: 680196DEAFBE7B3256-803C
Address 20: High Beam Assist. (J844)       Labels:. 8S0-857-511.clb
   Revision: AA001001
   Coding: 0404001C00000000000000
   Shop #: WSC 03607 002 104857
   ROD: N/A
   VCID: 2ECB0220CF9CC7A486-807A
No ASAM data for: "EV_HighBeamAssisAU316" (VW25)
   Component: IMMO          H04 0805
   Shop #: WSC 00000 000 00000
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
   VCID: 2ACF0A14D768EF8066-807E
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
   Component: RNS-MID       H06 5218
   Revision: AB001001    Serial number: VWZ6Z7L7654213
   Coding: 04000442040000A10001
   Shop #: WSC 12345 123 12345
   VCID: 37D0F44DEBAB9D65DE-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V14  8477
   Part No: 6R0 423 156 B
   Coding: 11221
   Shop #: WSC 00788
   VCID: 2FC804255F93CDAD9E-807A
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 7710740DE3EB1DA5DE-8022
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
   Serial number: 40000000050821
   ROD: EV_RDKBERU30.rod
   VCID: 37D0F44DE3AB9D65DE-8062
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3BDCEC5913DF7579FE-806E
End-------------------------(Elapsed Time: 04:32)--------------------------
A perfect day at my VW dealership. :D Image
27 degrees. I'm jealous. :mrgreen: :oops:
benzinkopf
iichel wrote:27 degrees. I'm jealous. :mrgreen: :oops:
i’m jealous everything inside the photos[emoji14]
Locked
