I'm new to this forum. I own a Vw Polo 2010 with a DSG 0AM Gearbox with 36,000mile on the clock. i bought it from a retired old lady few months agoI was having a delayed accerelation on standstill when taking off but once it takes off gear changes are good. I learnt on this forum that resetting the gearbox might fix things. I borrowed a friend VCDS and did a ROSS TECH 7speed basic reset but it always ends up with 255/85/0. Driving the car after made the delayed accerelation much worse. I decided to take it to a gearbox specialist to correct my mistake which they were able to do. The specialist told me that he has corrected the failed reset and everything is fine by recoding and doing a DSG adaptation.
I was much happier until i took the car and it was jerking from D2 to D5. It's much worse especially when driving up a hill but less noticeable when you hard accerelate from stop. Sometimes i do hear a clunk when downshifting and slowing down but thats intermittent. The car wasnt jerking when i took it to the specialist but it was a bit hard sometimes to get going from stop.
Did i do something wrong? The specialist said there is no code on the transmission to know what is going on. I do blame myself for trying to do fix something that isnt broken. A friend mentioned that it takes time for the gearbox to learn, that it should get better with time.
BELOW IS THE AUTO SCAN RESULT
Thursday,23,October,2025,19:06:23:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 25.3.0.3 (x64)
Data version: 20250301 DS365.0
www.Ross-Tech.com
VIN: WVWZZZ6RZAY260208 License Plate:
Mileage: 55950km-34765mi Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZAY260208 Mileage: 55950km-34765miles
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 BJ HW: 03C 906 024 BH
Component: CGGB MM4HV 8997
Revision: --H09--- Serial number:
Coding: 0000077
Shop #: WSC 00490 210 178676
VCID: 67DD0E9B556DDDA361-515A
VINID: 9E69EAAAA1A2A91A4218008020E7335209
Readiness: 0000 0001
Part No SW: 0AM 300 048 R HW: 0AM 927 769 D
Component: GSG DSG AG7 402 9031
Revision: 00040024 Serial number: TFK01003310754
Coding: 0000020
Shop #: WSC 45854 001 1048576
VCID: 3F8DF6FB6D7DB563F9-513C
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AF HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0005
Revision: --------
Coding: 230228E3417300B2C42714E282D900801100
Shop #: WSC 02069 000 00000
VCID: 020B3F0F990F188BD6-8056
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AP.clb
Part No SW: 6R0 820 045 J HW: 6R0 820 045 J
Component: Climatic 24 0660
Revision: 00 10 24
VCID: 356194D39C417F3323-8060
Part No SW: 6R0 937 087 D HW: 6R0 937 087 D
Component: BCM PQ25 H+4 H46 0207
Revision: BF046001 Serial number: 0147 100102813
Coding: 24B029BF08A10000002000003D2B0CD00040410F60060000200000000000
Shop #: WSC 124697 483 00190
VCID: 3E738BFFA977BC6BF2-806A
Subsystem 1 - Part No SW: 6R0 959 802 R HW: 6R0 959 802 R Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 006 0912
Serial number: KU0-KU025.03.1013599
Coding: 08BC30
Subsystem 2 - Part No SW: 6R0 959 801 T HW: 6R0 959 801 T Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 006 0912
Serial number: KU0-KU025.03.1016119
Coding: 08BC30
Component: VW10Airbag00A H08 0020
Revision: -------- Serial number: 003GX000YEV2 Dataset Number: v00304706R0 0001
Coding: 003041
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9BD72FEDBF00CB5E-801E
Serial number: 3572SRB40000B2DCAA0G
Crash sensor for side airbag: passenger side:
Serial number: 3582SRB40000B15D32A4
Serial number: 3515RRB40596PGAKF0O+
Serial number: 3525RRB404R6ORG83H12
Part No SW: 6R0 920 960 D HW: 6R0 920 960 D
Component: KOMBI H03 0207
Coding: 440200
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
VCID: 366393DF8947742B2A-8062
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087 D
Component: GW-K-CAN TP20 0207
Coding: 002100
VCID: 70EF65C7A3A31A1B30-8024
Component: IMMO H03 0207
Serial number:
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
VCID: 6ADB77AF8D7FE0CB7E-803E
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F6DA6BBEA1D45E369-807A
Part No SW: 5M0 035 186 AA HW: 5M0 035 186 AA
Component: Radio RCD310 016 0049
Revision: 01000000 Serial number: VWZ1Z2K7086911
Coding: 0500040002
VCID: 6BD572AB8A85F9C305-803E
End-------------------------(Elapsed Time: 02:40)--------------------------
---------------------------No fault code found.----------------------------
Jerking on DSG DQ200 after failed Basic Reset
buckycasuals
- Drives: POLO 6R 2010
Re: Jerking on DSG DQ200 after failed Basic Reset
You probably has a wrong firmware flashed to your dsg tcu. Wrong firmware can cause jerking and rough gear changing. Firmware depends on VAG brand/model / engine displacement and gearbox model. Find a VAG specialistto help you
