CNK
Drives: 6R
Post by CNK »
ciclo wrote:
Ugabista wrote:Lights in air vents? That which was very cool...:)
No friend :wink: , yet, do you know of anyone who has done it? Link, guide, tutorial, or seemed ...
Bachecco wrote:New radio MIB II
You mean this radionavigator?
Discover media 5C0 035 680 B
C + DAB
http://www.vwitalia.it/forum/f108/gtd-v ... 5-569.html
http://www.mk5golfgti.co.uk/forum/index ... c=94138.30
http://www.drive2.ru/b/1797054/ :lol:
No, it isn't the radionavigator, but ... it's very likely that someday I install it on my Rline, I am very pleased with my RNS510, works like a charm.
I found the information that the radio (Discovery Media 5C0 035 680B) is working in our Polo:
http://www.factory-retrofits.co.uk/vw-d ... le-tiguan/
And it can be installed in the following with a retrofit harness:
VW Golf Mk5 & Mk6
VW Passat B6 & CC
VW Touran
VW Jetta
VW Tiguan
VW Eos
VW Scirocco
VW Caddy
VW Amarok
VW Sharan Mk2 (2010+)
VW Polo Mk5 (2009+)
VW T5 (Transporter/California/Caravelle/Multivan)
So it's possible and p&p :O :mrgreen:
And here, Touran 2011 with Discover Media: https://m.facebook.com/story.php?story_ ... 1368022887
https://www.drive2.ru/b/1797054
:shock:
ORiOn
Drives: Polo BlueGT / Audi S5
Post by ORiOn »
I'm really interested on the radio!
If I find a good price I will definitely buy it! And with all your guys help, i'm sure one day we will make it work 100%! :D
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
ciclo wrote:
firegrafik wrote: Look forward for you report with managing CCS by the MFSW.
At the moment I can only say that this is the right way ... viewtopic.php?f=56&t=58703&start=1950#p506147
That is why I look forward for the details from you. There are many question appeared in my mind when I had read your lasts posts :lol: . The main question for me now is: Is it time to search Polo's 6C MFSW with CCS buttons? like this
or I should wait for some time
Ugabista
Drives: Vw Polo 6R 1.6TDI 90CV CAYB
Post by Ugabista »
Excelent news CHK :)
...but i can not find with RVC imput... :roll:
firegrafik
Marjacic wrote:Ciclo, could you maybe help me :lol:
i am looking to order the 7E0 bcm soon
with witch pqr number do i have to order when i order it?
polo 6R Tdi 105 hk 2011 :)
Hello,Marjacic!
Because I am newly registered user, I am unable to write/answer private messages. For this time please send me an email [email protected]
The title of the Youtube video is a bit misleading though.
The all-on-one headunit is the PQ version like T6, Scirocco, Beetle.
The split unit like Polo 6C, Golf 7 etc is the MQB version. Keep this in mind.
favi
Drives: 6R
Post by favi »
Do only these two controllers work for folding mirrors ( mirror engines 6R0959801BD Z0D, 6R0959802BF Z03 )? It's really hard to find those ones. I only found 6R0959801BD , it comes from vw Beetle. There is a big problem with the other one. Can anyone help? I have a mirrors regulator and mirrors from 6c. I hope that they are gonna work.
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
ORiOn wrote:I'm really interested on the radio!
There is a guy here in Denmark that can make it work. I got a quote of 16.500 DKK (£1742) for him to fit it in my Polo. (That includes a new BCM)
CNK
Drives: 6R
Post by CNK »
woooow, this is very expensive :P
I know man who has found an interesting auction and bought them for 900 PLN (£162) :lol:
https://www.youtube*.com/watch?v=hpZ_57Vf0yU
Yes, he bought this used radio with these pictures... :lol: :lol: :lol:
http://www.vwgolfv.pl/viewtopic.php?f=8&t=14424
wamba
Drives: polo 1.2tsi
Post by wamba »
hi ciclo
I need your help please
I would add a second video input on my RNS 510
you know if there is an adapter for it
firegrafik
ciclo wrote: ... my question about T73a/9, T73b/69 is a simple curiosity. :wink:
Maybe one of both pins is related with ...
Fernando, have you found out what is the T73b/69 pin for?
Could it be the "out, power supply to T73b/45 and engine ECU" for CCS by MFSW?
firegrafik
ciclo wrote:New mod VCDS:
Single LED DRL off when indicator is blinking.
09: Cent Elect---byte 23---bit 7----0->1 binary.
Fernando, I found out some more bits descriptions for 23 byte:
changing bit 4 from 0 to 1 switches off the DRL when the parking brake(handbrake) is on
changing bit 3 from 0 to 1 selects low beam as DRL, plus LEDs(or halogen DRL) are switched off
changing bit 2 from 0 to 1 selects cornering lights (fog lights) as DRL, plus LEDs(or halogen DRL) are switched off
So do you have coding information, that DRL works only when light switch on "Auto" position? And when it is on "0" position - the DRL is off.
These are the functions of byte 23 that I know:
byte 23
bit 0 Alternative voltage supply for high beam and T58d (button illumination)
bit 1
bit 2 Cornering lights as DRL and LED DRL off - xenon only
bit 3 Low beam as DRL and LED DRL off - xenon only
bit 4 LED DRL off with handbrake on - xenon only
bit 5
bit 6 DRL active
bit 7 LED DRL off unilateral with indicator on - xenon only
Byte 23 bit 6 probably disables DRL competely, also in Auto mode.
I don't think that it's possible to have LED DRL off in setting '0' but on with auto.
Maybe if you remove the DRL pin from light switch (T10/9 on light switch) but I'm not sure.
firegrafik
iichel wrote: ....
bit 5
bit 6 DRL active
Hello iichel!
My polo has halogen H7/H7 headlight and halogen foglight (for now) and bits 2,3,4,6 work. But because of my foglights don't have the DRL section I couldn't check the 7th bit workability. But soon I will set the Polo 6C front bumper up and double-section foglights with DRL, and then check it
https://www.drive.net/l/7796984/
I read that on the other VAG models, based on PQ35 BCM , it is possible, by coding changes, make the DRL off in "0" position, but workable on "Auto". So I'm sure that the same is possible for PQ25 BCM.
ORiOn
Post by ORiOn »
Do you know what bcm is needed?
Locked
